Pocket GPS World :: View topic - Shutting down on android 7
spaceprobe
PostPosted: Fri May 19, 2017 5:13 pm    Post subject: Shutting down on android 7 Reply with quote
I cant find an answer anywhere and my speed cam app as now become unusable. Since the update to Android 7 the app runs for a bout 10 minutes then shuts off. I have gone into battery saver etc and made sure that is not the issue it just wont play ball
PostPosted: Fri May 19, 2017 6:26 pm    Post subject: Reply with quote
Not universal with Nougat because it stays alive on my HTC One m9
Have you checked Nougats new 'optimise' settings as that could be shutting it down. If you have a HTC then check Boost+ as that does a similar trick of shutting apps it thinks aren't open/running.
I know Norton had to update it's Android app because Nougat optimise was shutting it down = oops.
PostPosted: Fri May 19, 2017 7:37 pm    Post subject: Reply with quote
Are you running it in the foreground or background?
abre
PostPosted: Sat May 20, 2017 8:36 am    Post subject: Reply with quote
I believe Android v7 introduced an OS level powersave which is similar to that in iOS and causes background apps to sleep, so as M8TJT asks...
See this http://www.androidbeat.com/2017/03/how-to-stop-android-apps-killed-marshmallow-nougat/
PostPosted: Sat May 20, 2017 9:00 am    Post subject: Reply with quote
Same as I said then
abre
PostPosted: Sat May 20, 2017 10:00 am    Post subject: Reply with quote
Yes...
GazzaW
PostPosted: Sun Jun 02, 2019 12:59 pm    Post subject: Re: Shutting down on android 7 Reply with quote
I have a OnePlus 6 running Android Pie. I have unoptimised Camera Alert and have 4GB free memory but the app stops running after 5 - 10 minutes meaning it's basically useless. There is a warning when installing the app that it's not optimised for Android Pie and may not run properly! The app needs to be updated so it's fully supported for Pie and doesn't get stopped by Android
PostPosted: Fri Jun 14, 2019 4:19 pm    Post subject: Reply with quote
Have a read of THIS and set CA to 'Active'. I think that should work
PostPosted: Fri Jun 14, 2019 9:33 pm    Post subject: Reply with quote
CamerAlert shows as 'EXEMPTED' and is not selectable on my OnePlus 5 (Pie).
However, I generally have it in the foreground with Google Maps overlaid in the corner.
PostPosted: Fri Jun 14, 2019 10:51 pm    Post subject: Reply with quote
Strange, I was able to set it on my S9+ Pie.
