Pocket GPS World :: View topic - PGPSW on GARMIN 50 LMT-D Questions please
jwmachon
PostPosted: Fri Dec 30, 2016 9:04 am    Post subject: PGPSW on GARMIN 50 LMT-D Questions please Reply with quote
Im thinking of getting a 50 LMT-D sat nav and installing the pgpsw database.
At the moment i use cameralert on android but having to do away with that
I have a couple of questions
1) When approaching a speed camera what warning will i get
2) if i go over speed limit during camera what warning will i get
3) in a average speed camera zone does it tell me if i go over 50 for example
4) is it directional like cameralert
many thanks,
Jonny
PostPosted: Fri Dec 30, 2016 9:16 am    Post subject: Reply with quote
1) Depends on how you install it. Using Kremmens convertor I get a voice that warns me of the camera along with it's speed at a distance you can set.
2) Not sure. Mine is set to only give one warning as it's all I need.
3) No
4) Can be I believe with some extra work, I don't bother
It also can't drive the car for you ... so I'm afraid having been warned you as the driver need to take action IF you're going too fast Wink
PostPosted: Fri Dec 30, 2016 9:26 am    Post subject: Reply with quote
Just to add to Sus's answer to 4. It's not directional as in CA, but you can set it up, with yet another oiece of softwate to give an alert such as "Fixed Speed Camera, 30 Miles Per Hour, West" Telling you which direction the camera is trapping.
It's a bit of a faff to initially set up the process, but once you have done it a couple of times, it only takes a couple of mins. Nowhere as easy as CA though, but well worth it. The default Garmin just gives a quiet bong and a blue dot indicating the cam's position, not to mention multiplke alerts for overspeed ac co-located cams (both ways on M/W gantry).
jwmachon
PostPosted: Fri Dec 30, 2016 9:38 am    Post subject: Reply with quote
Thanks guys I would of like a warning if I go over speed limit by accident whilst approaching or going past camera after initial warning mistakes do happen I though there was a overspeed warning
PostPosted: Fri Dec 30, 2016 11:04 am    Post subject: Reply with quote
jwmachon wrote:
I approach a speed camera and go above speed limit will it warn me that im above the limit till I slow down
Yes it will if you want it to. The overspeed warning time is adjustable in Kremmens CSV-GPX converter.
and also how does it work going through specs
It doesn't calculate and display your average speed, if that's what you mean. It just tells you there is a SPECS camera there.
Using Kremmen's software gives an overall much better experience that the bog standard Garmin alerts with only a blue dot on the screen and a quiet bong. Kremmen's prog puts 'proper' icons on the screen, spoken alerts, and no multiple alerts for the same and adjacent cams (unless you set an overspeed alert, which you seem to want to do). The Garmin speed cam offering is really quit poor in its implementation.
PostPosted: Fri Dec 30, 2016 11:21 am    Post subject: Reply with quote
A recent idea I put into the Converter was an adjustable overspeed warning limit.
Garmin sometimes is a bit too keen to warn you, again, when you are even slightly under the limit so you can, say, set the overspeed for a 50mph camera to trigger at anything up to 57mph, but no more, (10% + 2mph for those that like to gamble).
PostPosted: Fri Dec 30, 2016 11:50 am    Post subject: Reply with quote
Shame we can't trap the alerts and UI to make our own SPECS calculations as you can do on iGO.
pcaouolte
PostPosted: Fri Dec 30, 2016 6:31 pm    Post subject: Reply with quote
Also considering getting a Garmin 50 LMT-D after many years with TomTom. Can the Garmin be set to warn for cameras "only on route" when using Kremmen's program and the PGPS world cameras?
Paul
PostPosted: Fri Dec 30, 2016 7:05 pm    Post subject: Reply with quote
No.
pcaouolte
PostPosted: Fri Dec 30, 2016 7:07 pm    Post subject: Reply with quote
Ok. Thank you for the reply.
Paul
PostPosted: Fri Dec 30, 2016 7:25 pm    Post subject: Reply with quote
But you won't get many warnings for off route cameras.
pcaouolte
PostPosted: Fri Dec 30, 2016 7:51 pm    Post subject: Reply with quote
That's good news. The off route cameras can be a bit distracting.
I'm trying to work out if I am going to like the Garmin before buying one. The newer TomTom's don't have the features I want.
I would like something thinner than my old TomTom GO710 as I want to mount it on a Brodit Proclip in my new car.
Paul
PostPosted: Sat Dec 31, 2016 6:14 am    Post subject: Reply with quote
You can mount all Garmins on a ProClip ....
Assuming you can still get the Brodit ball mount. I've got one in stock just in case.
What it is is a small chunky 1" piece of plastic with a 4 hole backplate and the Garmin ball on the other end.
Yep, DSLDevelopments, item number 215547
pcaouolte
PostPosted: Sat Dec 31, 2016 10:12 am    Post subject: Reply with quote
Thank you Kremmen, that looks ideal.
Paul
b33jay
PostPosted: Tue Jan 03, 2017 5:51 pm    Post subject: Reply with quote
Buy a cheap vent mount and remove the clips then either drill it or use double sided tape.
http://tinyurl.com/zotzynm
22.123 (18 Dec 24)
