Pocket GPS World :: View topic - Nuvi 55 LMT questions
doobs
PostPosted: Sat Jul 18, 2015 12:46 am    Post subject: Nuvi 55 LMT questions Reply with quote
Folks - I have a couple of questions regarding this unit
1. When I plug the unit in via official garmin usb lead to pc, it recognises the Nuvi but defaults to Mass Storage Device, even though I have selected MTP auto detect on the unit - how do I get it to default to MTP?
2. If I try to charge the unit with the garmin usb lead into a standalone usb mains charger it changes to normal start up mode but then says "the attached power cable can not charge your device. use the cable provided" - I am using the cable provided! Do I have to get a separate mains charger - if so an aftermarket one or a garmin one?
PostPosted: Sat Jul 18, 2015 8:22 am    Post subject: Reply with quote
1. Does your PC meet the system requirements for mtp mode?
https://support.garmin.com/support/searchSupport/case.faces?caseId=%7B2c197420-8419-11e1-6a4c-000000000000%7D
2. You'll get this message if there isn't sufficient power, and possibly also from non Garmin chargers. If it charges your nuvi you can simply ignore it.
doobs
PostPosted: Sat Jul 18, 2015 5:01 pm    Post subject: Reply with quote
I am running windows 8.1 with media player 12, so yes - any other ideas?
PostPosted: Sat Jul 18, 2015 5:48 pm    Post subject: Reply with quote
No, but I wouldn't worry, the first thing I did when I got my 2508 was set it to mass storage mode Wink
PostPosted: Sat Jul 18, 2015 5:57 pm    Post subject: Reply with quote
That MTP auto detect must be auto detecting something unusual and assigning a drive letter by default.
Satnav:
Car Average MPG :
doobs
PostPosted: Sat Jul 18, 2015 6:11 pm    Post subject: Reply with quote
is there a benefit to mass storage mode then? I seem to prefer mtp as I can into the unit whilst it is under usb power
PostPosted: Sat Jul 18, 2015 7:03 pm    Post subject: Reply with quote
You can't access .system folder on later nuvis unless they're in mass storage mode.
22.055 (29 May 24)
