oldie70 Occasional Visitor
Posted: Mon Nov 18, 2013 1:43 pm Post subject: New user of 52LM - a few questions. |
I haven't had the unit in the car yet, but I've been running routes in simulator mode, and I've ended up with a few questions about very minor problems.
These are in no sense complaints, and there are obviously ways round all of them. They're simply minor drawbacks compared to my old device ( a tomtom, bought 4 years ago at twice the price).
Overall it's a very nice unit, and a lot of thought has been put into the design from a user's viewpoint.
I've downloaded the manual, and I can't see any mention of these points, though I could easily have missed them.
1. Can I simulate driving a route a speed better than 1:1 ?
2. With the unit plugged into my laptop for charging, I just have a screen saying "GARMIN", a blue triangle and a small picture. Ejecting (not physically) and restarting the device takes me to the same screen. Is it possible to use the unit while charging?
3. After running a route, and pressing Stop, the location is left at the destination. Is there a quick way to reset the location to Home?
4. In 'View Map', is there any way to select an address, or do you have to zoom out and find the point you want?
5. When setting a location on a dual carriageway (usually a via) is there a way to set which side you want the location to be? Is the direction of the small arrow significant?
6. The only junction I can actually find is that of the A3 and M25. I'm then offered four options in the form: road(direction) road(direction). Does 'direction' refer to 'from' or 'to'? Or 'from' and then 'to'?
Thanks in advance for any replies. |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4462 Location: West Sussex
Posted: Mon Nov 18, 2013 2:01 pm Post subject: |
1. Unfortunately no.
2. Ditto But you can if it's plugged into a wall charger.
3. If you switch off and switch on again I think that should work (it does on my 2508 and 1490).
4. I don't understand that one?
5. Nope, just need to zoom in far enough so you select the right one.
6. Direction of travel along that road.
HTH  |
Posted: Mon Nov 18, 2013 4:44 pm Post subject: |
Thanks for the reply.
1. Pity - but it's useful for the charge/discharge battery cycle.
2. I was going to come to wall charging, since it seems very slow at charging from the USB socket. I have my old tomtom charger, with the same mini-usb plug. I also have two wall plugs with USB outlet. One is for my iPad, the other for my mobile phone. I assume it's safe to use any of these to charge the unit?
3. I have to remind myself that switching off also switches off the GPS simulation. I've also found I can use Where To? / Home. and then use "Set Loc".
4. I was under the impression that you had to use "View Map" to set a new start location (while in simulator), and there's no way that I can see to identify a point on the map to start looking from. However, I've now found that you can use Where To? to find a location, and set a new start location, but for that point only. You then go back to Where To? / Browse Map to set a new start location.
I use this to test out what happens at a specific junction or tricky part of a route.
5. Sometimes it will give a direction, as in "A1(N)" , but usually not. So it's a case of seeing how often the route take you along that bit of road.
6. So it's always the direction you're travelling towards? Driving SE along the M25, to turn left onto the A3 NE would be M25(SE)A3(NE)? |
Posted: Mon Nov 18, 2013 4:48 pm Post subject: |
That about sums it up ... once you get used to it it becomes second nature  |
Posted: Tue Nov 19, 2013 12:16 pm Post subject: |
And any thoughts on the use of a wall charger intended for a TT, iPad or mobile phone? |
Posted: Tue Nov 19, 2013 1:05 pm Post subject: |
Sorry, missed that. I use a generic wall charger and never had any issues. |
Posted: Tue Nov 19, 2013 8:59 pm Post subject: |
Ok, thanks. My three chargers have the details in raised plastic, which I hate. So far as I can see, they all output 5V. I'll try one tomorrow!  |
Posted: Tue Nov 19, 2013 9:53 pm Post subject: |
Just for info mine provides a 580mA charge. |
Posted: Wed Nov 20, 2013 1:38 am Post subject: |
I've done some research, and they're either interchangeable, work slowly or don't work at all, depending on the output current compared to the current the device expects. Most devices need 0.5A, but Apple devices usually need more, so an Apple USB wall plug can be used for most devices.
The voltage is virtually the same for all - 5.0V or 5.1V.
That's provided they're genuine plugs, of course. Cheap (usually Chinese) imports are dangerous in all sorts of ways. |
M8TJT The Other Tired Old Man
Posted: Wed Nov 20, 2013 9:45 am Post subject: |
oldie70 wrote: | I've done some research, and they're either interchangeable, work slowly or don't work at all | How much research did that take??  |
Posted: Wed Nov 20, 2013 12:20 pm Post subject: |
Not long, but the possibility I wanted to rule out was that the wrong one could blow up the device. |
