Pocket GPS World :: View topic - database install nulink 2390
themagicmaster
PostPosted: Fri Mar 01, 2013 9:37 pm    Post subject: database install nulink 2390 Reply with quote
help please, new user, just downloaded and installed database to my device, looking in the poi folder it lists 'garmin speed.gpi' is this correct, does garmin's poi loader covert the original csv files/ mp3 files to a single gpi file. Was just trying to check all downloaded correctly. Thanks
walkerx
PostPosted: Sun Mar 03, 2013 11:53 am    Post subject: Re: database install nulink 2390 Reply with quote
When you run POI Loader it will supply the name of the GPX file to use, which you can then change - But yes it will convert all files into a single file for the garmin.
Also the nulink 2390 does not work with MP3 files, you need the WAV files instead.
And remember to download sox from PGSPW (link found in another thread) and save the exe in the poi loader application folder
themagicmaster
PostPosted: Mon Mar 04, 2013 6:32 pm    Post subject: all sorted Reply with quote
Thanks for the info, downloaded wav file, intalled sox. tested on the road, all appears to work. thank you for your help.
carl_w
PostPosted: Mon Mar 04, 2013 11:20 pm    Post subject: Reply with quote
Sox? What does that do? I've been using POILoader on a Mac with no problems without it.
PostPosted: Tue Mar 05, 2013 8:14 am    Post subject: Reply with quote
SOX.exe is a third party utility that converts .WAV files into a format that the Garmin via the POILoader can understand.
With SOX you can have spoken warnings, without SOX you just get bongs.
Your choice between something like "Gatso ahead, speed Limit 50 miles per hour" or 'Bong' Very Happy
walkerx
PostPosted: Tue Mar 05, 2013 9:19 pm    Post subject: Reply with quote
You sure it's not a Bing Laughing
carl_w
PostPosted: Mon May 27, 2013 11:43 pm    Post subject: Reply with quote
I just upload the wavs with the speed cam files and it works fine?
23.012 (08 Jan 25)
