Pocket GPS World :: View topic - New firmware being offered Version 11.030 for Go Live 1000
Goto page Previous  1, 2, 3
PostPosted: Mon Feb 13, 2012 2:39 am    Post subject: Reply with quote
HenryMitchell wrote:
It all works as you describe but if you have chosen the "Ask me" option it doesn't show you a map of the alternative route so when it asks you if you want to switch routes you don't know what you are switching to!
Even if you ignore the message box and tap bottom right of the status bar?
"Settling in nicely" ;-)
HenryMitchell
PostPosted: Mon Feb 13, 2012 12:21 pm    Post subject: Reply with quote
Yes, the bottom right tap just shows a summary of the current route.
You can get a comparison of old and new routes with an option to revert to the original, but only if you manually ask for an alternative route or manually ask to avoid a reported traffic incident.
Device: GO 600, Live connected via iPhone 5.
App: 13.030.1412491.111 (0) (2042, 31/10/2013)
OS: 1392579
Map: Europe v920.5244 (11/2013)
HummerUK
PostPosted: Tue Feb 14, 2012 3:02 pm    Post subject: Reply with quote
I bit the bullet and renewed my Live sub and map subscription.
Anyway, on Sunday was my first trip, click on recently used destinations and it reported back it was impossible to navigate to the location.
Tried a couple more with the same issue as it did from my custom poi list.
In the end, I just had to guess the address as I could not recall all the detail.
Doing a google, I found it suggested a factory reset which works but in the favourites now all I get a name with the old favourite star rather than a choice of icons which I think the new software added.
Not a big deal, but I can find no way to change them so they have different icons (unlike the ones it auto created that did not work).
HummerUK
PostPosted: Tue Feb 14, 2012 5:37 pm    Post subject: Reply with quote
I'm not sure about your last sentence, but to get the "Favourite destinations" back, you go to Start-up preferences and select "Ask me for a destination". You can then configure the Favourites you want to use.
EDIT: For completeness, I should add how to get rid of them again!
To make them NOT show on start-up, just go back to Start-up Preferences and select one of the other two choices.
But that still leaves them on the Navigate to.... Favourites page.
To get rid of them from there, you need to go to "Configure" on the Favourites page, say "Yes" to the next question (I know that seems wrong!) then un-select all the destinations except "Home", then answer "No" to the question about changing addresses.
Once you've done all that, the NEXT time you go to the Favourites screen, they should be back to the normal long list.
HummerUK
PostPosted: Wed Feb 15, 2012 10:29 am    Post subject: Reply with quote
Many thanks,
As my device wants to install another 24 files I will get it out of the car and try.
EDIT:
Still no luck, under navigate to favourites all I can get is the star list and no joy trying to change the format.
Under settings, start up all I get is "Continue where I left off", "Ask For A Destination" or "Show the main menu".
HummerUK
PostPosted: Wed Feb 15, 2012 7:42 pm    Post subject: Reply with quote
@ Hummer... I'm possibly getting confused what you want now!
If you want to be asked for "Favourite destinations" when you switch the power on, then you DO select "Ask For A Destination" in Start-up preferences.
You should then get a whole procedure to choose between 1 and 11 destinations to be used.
HummerUK
PostPosted: Thu Feb 16, 2012 1:16 pm    Post subject: Reply with quote
I shall try and take some pictures to explain...
However, at the moment my one wants to install new software, Europe map and you guessed it speed cameras Smile
HummerUK
HummerUK
PostPosted: Thu Feb 16, 2012 3:16 pm    Post subject: Reply with quote
My one is now 11.031.860447.74 with map 'Europe' v885.4007, Release date: 1/2012
Back to my Favourite issue Smile
If I touch Navigate to.. then Favourite I just get a list of names with a star to the left.
Before I did the factory reset it had under Favourites had icons for destinations with I think the option to change the icon to a picture of a building a the profile of a persons head.
This now seems to have gone.
Not of course that it is that important Smile
HummerUK
scotty76
PostPosted: Fri Feb 17, 2012 11:43 am    Post subject: Reply with quote
Over the last week I've seen two new things I've never seen before:
1. When there was traffic on the route a new bar appeared at the top of the screen with the words "Alternative route 2 minutes quicker" and a few minutes later "Alternative route no faster". The wording might be out but that's the gist of it. This also had a green square within the bar which if tapped asked if I wanted to switch to that route. I hope this isn't instead of the fullscreen prompt + spoken prompt that used to come up "the traffic delay on your route is now x minutes, a faster route is available..." with the voice activated Yes/No option. I don't touch the sat nav when driving.
2. I got a red triangle with a car and what looked like rain or ice behind it on the screen. This appeared next to the zoom icon in the top left of the screen. Digging through the old manual I'm guessing this is a weather warning for my route but the old manual suggested this would be on the traffic bar on the right. Maybe it has moved?
PostPosted: Fri Feb 17, 2012 4:17 pm    Post subject: Reply with quote
OK. Have you tried what I said in the post above?
HummerUK
PostPosted: Fri Feb 17, 2012 9:00 pm    Post subject: Reply with quote
Many thanks
You are indeed a genius.
I see now that wizard option only runs when startup is set to "Ask for a destination".
HummerUK
erinafare
PostPosted: Fri Feb 24, 2012 12:58 am    Post subject: Reply with quote
I was also getting the alternate route quicker message but found it awkward to touch the screen whilst driving so unless it was more than 15 minits delay ignored it. Last time I had the message was at the weekend. Today got the voice activated message worked like a dream much better than trying to jab the screen. Could this have been part of update a couple of days ago. I have not touched any settings since last using satnav.
Very happy so far with new screen icons and menus.
Now have 1005 not Go530 as specified on screen do I change info in profile.
Christine from Essex Grey Surfer but young at heart.
Love all the modern technology
Go 1005
PostPosted: Fri Feb 24, 2012 3:38 am    Post subject: Reply with quote
Go to the top of this screen and you should see a link for "Profile" in the white bar.
Click on that and the box to change your signature (the bit that shows at the bottom of your posts) is about 2/3 down.
scotty76
PostPosted: Fri Feb 24, 2012 9:47 am    Post subject: Reply with quote
Ditto. I never touch the sat nav whilst driving so it went from being a usable feature to useless. I'm glad to hear it seems to be back to the way it was as I much prefer this. Thanks for posting.
erinafare
PostPosted: Fri Feb 24, 2012 10:19 am    Post subject: Reply with quote
Thank you both for your replies.
As you can see have now changed my profile. Very Happy
Go 1005
Page 3 of 3
23.052 (14 May 25)
