alanw47 Occasional Visitor
Posted: Tue Nov 15, 2011 4:34 pm Post subject: Software Update Available |
I have a Garmin Nuvi 1340LMT which is up to date with the latest maps and software (v 5.40). Despite this the Garmin website is constantly telling me that there is a software update available, which is in fact version 5.40, but WebUpdater tells me it is up to date. I have re-installed v 5.40 but nothing changes. Has anybody else experienced this and is there a cure? |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Tue Nov 15, 2011 5:45 pm Post subject: |
Yes, it's a known bug, and no, so far no cure |
Posted: Wed Nov 16, 2011 10:07 am Post subject: Software Update Available |
sussamb wrote: | Yes, it's a known bug, and no, so far no cure |
Thank you, I'll just learn to ignore it |
Posted: Wed Nov 16, 2011 12:08 pm Post subject: |
Just released! Note this fixes the bug that came with 5.20 that causes favourite icons to only display as black squares.
nuvi 13xx and 14xx series (GCD File) software version 5.70
as of November 15, 2011
WebUpdater is required to install this file — What is this?
(16.53 MB)
View system requirements
Change History
Changes made from version 5.40 to 5.70:
Added new Fleet Management Interface features.
Fixed Fleet Management Interface errors.
Added support for Maged, a new Arabic text-to-speech voice language.
Fixed an error that caused TrafficMaster UK subscription to display as 'New Subscription' when using a GTM 25.
Fixed map display errors.
Fixed POI search errors.
Fixed route calculation and display errors.
Fixed an error that caused location information to not appear on the Go! page for certain Points of Interest. |
Posted: Fri Nov 18, 2011 2:26 pm Post subject: Software Update Available |
Thanks for that. Didn't fix my problem, MyDashboard still tells me that a software update is available but Web Updater tells me it's up to date, so I'll just trust that in future. |
Posted: Sat Nov 19, 2011 12:33 pm Post subject: |
I would ... that's what most folks do |
CDK Regular Visitor
Joined: Apr 20, 2006 Posts: 122 Location: Ashford. Kent. UK.
Posted: Sat Nov 19, 2011 4:07 pm Post subject: |
Hi alanw47
Not sure if this will help, but I had a similar problem with my Garmin 1690 a while back.
In my case both Webupdater and Dashboard showed an update waiting and despite numorous update attempts the same file would show up as waiting to be downloaded. In my case it was a "1690 Help" file.
Garmin support only sent me instructions for Webupdater which did not answer my question.
However using Windows Explorer, I looked through all the directories on the Garmin - though not sure what I was looking for... BUT I found that there was a "chkdsk" type error file in the "Help" directory on the 1690 which I thought was unusual.
I renamed this error file (adding a "x" to the end of the filename - did not delete, just in case), and then tried Webupdater and also Dashboard; the update went through on both - the next time I logged on there was no file waiting!
You can see my original post:
[/url]http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=86660&highlight=
PLEASE NOTE: As usual, do not delete or rename any file on the Garmin unless you are absolutely certain, and/or are willing to bear the consequences; especially if it is still under guarantee (ie on your head be it) !
Regards
CDK |
Posted: Mon Nov 21, 2011 10:43 am Post subject: Software Update Available |
Thanks to you both for your suggestions, I eventually updated a couple of voice files via WebUpdater and the problem has gone away. |
