Pocket GPS World :: View topic - TomTom iPhone 1.7 Custom POIs broken again?
st1967
PostPosted: Tue Apr 26, 2011 2:56 pm    Post subject: TomTom iPhone 1.7 Custom POIs broken again? Reply with quote
Just upgraded my TomTom on the iphone to 1.7 and while custom POI's are working they just display as a red squares on the map.
Searching on T'Internet this appears to be what originally happened until the .PNG extension rename fixed it?
I've tried as BMP again but it's the same.
The odd thing is though is that when you actually browse through the POI category when choosing your destination that logo displays fine there, it just in actual map view you get the reg square ?
I guess as long as you can still navigate to your custom POI it's not the end of the world, but a bit of a bummer if you do the Speed Cameras Update from here?
Samsung S22 Android, Google Maps & Camera Alert
st1967
PostPosted: Tue Apr 26, 2011 3:42 pm    Post subject: Reply with quote
Thanks to Mike's suggestion they appear to work as proper PNG files (rather than renamed BMP files) but some still not working?
I am working with the PGPSW POIs collections and icons and ones that still don't work as true PNG are
Aldi
McDonalds
Morrisons
Pizza Hut
It seems to be something to do with "Bits Per Pixel" as the ones that work are all set at 24 bits per pixel, and the non working are 8 bits per pixel.
Currently working through all my POI icons and increasing the colour depth the 24 BPP and that should fix them all.
Oooh what a palava Laughing Out Loud Let hope the map updates are worth it Laughing Out Loud Rolling Eyes
Update: Converting all icons to 24 BPP (bits per pixel) PNG files worked
PostPosted: Tue Apr 26, 2011 4:24 pm    Post subject: Reply with quote
Nice one, the change to pure PNG file was a logical step though to be honest as the previous method of simply renaming a file was raqther a "cludge" - Thanks for confirming this - Mike
PostPosted: Tue Apr 26, 2011 4:40 pm    Post subject: Reply with quote
Is this something we should think of as an improvement for the PGPSW POI downloads?
PostPosted: Tue Apr 26, 2011 9:03 pm    Post subject: Reply with quote
Which 'something'? .png or 24bit.
TT Via 135 App 12.075: Europe Map v1140
PostPosted: Wed Apr 27, 2011 1:45 pm    Post subject: Reply with quote
You know what I'm going to say.....
Both! Laughing
st1967
PostPosted: Wed Apr 27, 2011 2:43 pm    Post subject: Reply with quote
Do 24bit PNG files work in standard TomTom devices? Ie those that normally accept BMP? If they do you could replace all icons with PNG files and save having to do multiple versions?
Although freeware such as irfanview (http://www.irfanview.com) converts them easily enough
senoj
PostPosted: Fri Apr 29, 2011 10:12 pm    Post subject: File convertion using infanview Reply with quote
Do I have to convert the .bmp to .png files ( working ok in TT 1.6) back to .bmp files before reconverting to True .png 24bpp using irfanview .... Want to fix the problem before upgrading to TT 1.7
Chris
PostPosted: Fri Apr 29, 2011 10:20 pm    Post subject: Reply with quote
The files supplied in the V1,6 download were bmp format simply renamed to .png so you need to do the following with your existing files:
1/ rename each ones file extension from .png to .bmp
2/ open each icon file in an image edit program and save as 24bit png
Use the resultant png files and the V1,7 software will display on the map and in the menu
Note, for the redlight icons you will need to save these as 24 bit bmp files prior to saving them as png files as the colour depth is only 8 bit - Mike
PostPosted: Sat Apr 30, 2011 6:38 am    Post subject: Reply with quote
All POI icons should now be 24bit BMPs.
If I've missed any, just let me know. Smile
senoj
PostPosted: Sat Apr 30, 2011 7:29 am    Post subject: png files Reply with quote
Thanks Mike.
I had renamed the files within diskaid... this was before the files were available for download. Does this make any difference to your suggestions?
Thanks for the help
Chris
22.123 (18 Dec 24)
