2216 Regular Visitor
Posted: Mon Dec 20, 2010 4:19 pm Post subject: New Home Critical update 2.8.0.2146 |
Critical update 2.8.0.2146. |
loro Lifetime Member
Posted: Mon Dec 20, 2010 8:25 pm Post subject: |
Still on 2.7.6.2056...no update given? |
Posted: Mon Dec 20, 2010 8:51 pm Post subject: |
Update offered after forcing it to check
Help menu - Check for Home Update |
Posted: Mon Dec 20, 2010 9:30 pm Post subject: |
Thanks both for the info but why the need to force a critical update? surely if it’s that critical it should be offered automatically ..but that’s TomTom for you i suppose |
Guivre46 Frequent Visitor
Joined: Apr 14, 2010 Posts: 1262 Location: West London
Posted: Mon Dec 20, 2010 11:47 pm Post subject: |
I think you need to have the 'automatically start Home on connection' or whatever it is set, to be offered it without prompting.
Mac version is 2.8.0.1019 _________________ Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom |
Posted: Tue Dec 21, 2010 11:09 am Post subject: |
Guivre46 wrote: | I think you need to have the 'automatically start Home on connection' or whatever it is set, to be offered it without prompting.
Mac version is 2.8.0.1019 |
Thanks Guivre46 but Home is set to start automatically on connection ? |
MrT Frequent Visitor
Posted: Tue Dec 21, 2010 11:53 am Post subject: |
This version of home start bringing up repeated messages about malformed data which was referring to the original LMG 815 North America download of around two years ago. I had to move this from the Home complete downloads directory to stop the message appearing. I have no idea why this suddenly started but there is nothing wrong with this download. _________________ Drivelux |
Posted: Tue Dec 21, 2010 12:10 pm Post subject: |
loro wrote: | Guivre46 wrote: | I think you need to have the 'automatically start Home on connection' or whatever it is set, to be offered it without prompting.
When I had mine set to automatic update, I was offered new Home versions on connection. Now I'm set to a more manual option and have to check in Help/ check for home update. Maybe TT has changed things again? _________________ Mike R [aka Wyvern46]
WackyRaces Banned
Joined: Aug 04, 2010 Posts: 172 Location: Banned Member Using New ID
Posted: Sat Jan 08, 2011 8:22 pm Post subject: |
MrT wrote: | This version of home start bringing up repeated messages about malformed data which was referring to the original LMG 815 North America download of around two years ago. I had to move this from the Home complete downloads directory to stop the message appearing. I have no idea why this suddenly started but there is nothing wrong with this download. |
Ditto I also manually checked tonight (Jan 8th 2011) for updates in Home 2.7 something or other and was offered this update to v2.8.0.2146 but after installing it I am now also getting a whole bunch of malformed data messages in relation to the North America map v835 (which would have been updated to that version via the LMG in June 2009) when I run Check For Updates.
Can the idiots at TomTom software development do absolutely nothing right and do they not test anything before releasing it out in to the wild.
Here are the error messages.
Quote: | ERROR: Internal/Malformed#createItemFromDLL/Internal/Malformed: Exception: We're sorry but HOME can't complete that task. Please try again later, or contact customer support. For problems with items that are stored on your device, we advise you to remove and re-install the item.
Malformed Item info:
name = North America
id = North_America
version = 830.2284
locationType = 1251
metadata =
Severity: 1105
Internal/Malformed: Malformed: We're sorry but HOME can't complete that task. Please try again later, or contact customer support. For problems with items that are stored on your device, we advise you to remove and re-install the item.
Bad character in alpha
Bad value: "USA AL Alabama" (type: string)
Severity: 1105
Stack:
0. chrome://tthome/content/logic/model/ttItemFactory.js:43
let wrapper = new Exception(null, newId);
1. chrome://tthome/content/logic/model/ttItemFactory.js:90
var modelitem = this.createItemFromDLL(dllitem, onlyType);
2. chrome://tthome/content/ui/subtask/installSelectSome/installSelectSome.js:827
let localItems = gApplication.itemFactory.createItemListFromDLL(gApplication.homeServices.localNavItems());
3. chrome://tthome/content/logic/util.js:79
return func.apply(obj, arguments);
4. function _startCommitFunction chrome://tthome/content/ui/bindings/ttwizard.xml:1057
5. chrome://tthome/content/ui/bindings/ttwizard.xml:1045
6. chrome://tthome/content/logic/util.js:79
7. chrome://tthome/content/ui/subtask/installSelectSome/installSelectSome.js:815
"downloadedItems", [item.name], 1));
8. chrome://tthome/content/logic/util.js:79
9. chrome://tthome/content/logic/model/ttNavItem.js:706
aSuccessCallback(result);
CAUSE: Internal/Malformed: Malformed: We're sorry but HOME can't complete that task. Please try again later, or contact customer support. For problems with items that are stored on your device, we advise you to remove and re-install the item.
Severity: 1105
Stack:
0. chrome://tthome/content/logic/serverinput.js:91
throw new Malformed("Bad character in alpha", uc);
1. chrome://tthome/content/logic/util.js:79
2. chrome://tthome/content/logic/serverinput.js:197
arrayOut.push(itemCheckFunction(arrayIn[i]));
3. chrome://tthome/content/logic/model/subtype/ttMap.js:144
this._coveredRegions = makeSafe.list(xml.region, makeCallback(makeSafe, makeSafe.alpha));
4. chrome://tthome/content/logic/model/ttNavItem.js:317
this.importFromXML(xml);
5. chrome://tthome/content/logic/model/subtype/ttMap.js:158
ttNavItem.prototype.importFromDLL.apply(this, arguments);
6. chrome://tthome/content/logic/model/ttItemFactory.js:39
result.importFromDLL(item);
7. chrome://tthome/content/logic/model/ttItemFactory.js:90
8. chrome://tthome/content/ui/subtask/installSelectSome/installSelectSome.js:827
9. chrome://tthome/content/logic/util.js:79
10. function _startCommitFunction chrome://tthome/content/ui/bindings/ttwizard.xml:1057
11. chrome://tthome/content/ui/bindings/ttwizard.xml:1045
12. chrome://tthome/content/logic/util.js:79
13. chrome://tthome/content/ui/subtask/installSelectSome/installSelectSome.js:815
14. chrome://tthome/content/logic/util.js:79
15. chrome://tthome/content/logic/model/ttNavItem.js:706
Time: Sat, 08 Jan 2011 19:13:11 GMT |
WackyRaces Banned
Posted: Sat Jan 08, 2011 9:38 pm Post subject: |
I notice that under Home Preferences/Advanced that the "Inform me when beta-releases are available for installation" box was ticked.
As this update wasn't offered automatically but only when I asked Home to check for updates is there any possibility that this defective 2.8 version is only a Beta release? Although I have now unticked the "I nform me of beta-releases box there seems to be no way to foll back to the previous 2.7 version of Home that I had installed. |
Posted: Sat Jan 08, 2011 9:47 pm Post subject: |
Just uninstall in the usual way and redownload Home from TT website. |
WackyRaces Banned
Posted: Sat Jan 08, 2011 10:34 pm Post subject: |
PaulB2005 wrote: | Just uninstall in the usual way and redownload Home from TT website. |
Surely that depends on whether or not 2.8 is now the official version as if it is that is what TomTom will now be offering on their website.
I also tried moving the North American latest map guarantee folder dating from 18 months ago elsewhere as suggested but it did no good and I still get the same errors when checking for the latest Updates for my 940. |
Posted: Sat Jan 08, 2011 10:45 pm Post subject: |
Quote: | Surely that depends on whether or not 2.8 is now the official version as if it is that is what TomTom will now be offering on their website. |
The version on the website will be the latest official NON-beta version. |
WackyRaces Banned
Posted: Sat Jan 08, 2011 11:45 pm Post subject: |
PaulB2005 wrote: | The version on the website will be the latest official NON-beta version. |
Well firstly we don't know if v2.8 is a Beta or not do we?
Unfortunately they only seem to be offering something called 1.6 for Navigator 6 at www.tomtom.com/services/service.php?id=16&tab=87 What on earth is that? Or are TomTom so utterly technically incompetent in all respects (even whilst granting that they so have a slick and well oiled marketing machine to shift their poorly constructed pieces of tat with bug ridden firmware) that they also haven't updated the wording of their download page to the actual version of Home now in use?
I notice there is also no mention of the web version of Home for the 1000 series on that web page. Or is v3 of Home only accessed by going to a TomTom website with a suitable user name and password and not by downloading any software? |
Posted: Sun Jan 09, 2011 12:23 am Post subject: |
The 1.6 download is a seperate Download for Navigator 6 for Windows devices. You want the download above that with the blue download button.
In the time it took you to moan about tomtom you could have uninstalled your current version and reinstalled the version off the website. |
