Pocket GPS World :: View topic - How long time find sat fix with clip on...
jlw
PostPosted: Wed Jun 09, 2004 5:21 pm    Post subject: How long time find sat fix with clip on... Reply with quote
yeah. how long time should it take to get a fix for the very first time?
Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case
PostPosted: Wed Jun 09, 2004 5:46 pm    Post subject: Reply with quote
Difficult to give an exact answer but assuming a cold start you should expect a fix in under a minute or two at the very most.
lbendlin
PostPosted: Wed Jun 09, 2004 5:48 pm    Post subject: Reply with quote
Assuming you take the receiver out of a depletion (or on a plane trip over the ocean) you need to expect a TTFF of up to 5 minutes with the receiver being in clear sky view with no obstructions.
You also need to consider that the sats are moving around all the time, so the TTFF is also a function of the current constellation and may take longer (or not) depending how the sats stand.
Here's a table
Lutz
TomTom/TeleAtlas NAVTEQ
jlw
PostPosted: Wed Jun 09, 2004 7:25 pm    Post subject: Reply with quote
I managed to work it out. Took a while. Smile
But now I got a differ problem. I have not buy tomtom3 yet. So I use nmeamoon. its a progg that record nmea traffic.
I getting some sats, but its loosing it after a few sek.. all the time. Sad
Fortuna Clip-On
CF: Lexar 256 MB
Poporta Alu-Case
lbendlin
PostPosted: Wed Jun 09, 2004 11:51 pm    Post subject: Reply with quote
What receiver are you using? Does it have any lights to indicate a fix?
Lutz
ichilton
PostPosted: Thu Jun 10, 2004 8:09 am    Post subject: Reply with quote
That's interesting - you are saying 5 mins from cold but I have a TomTom silver wired GPS with TomTom v3 (with the latest updates applied) and most of the time it's ok, but sometimes when I plug it in (thinking about it, it might be mainly after i've not used it for a few days or I have moved without the PDA connected then plugged it in somwhere else) it takes about 10 minutes or so to get a fix - is this not normal?
It did it last week - I was on holiday at Center Parcs - used it to drive there fine, parked in the car park from Monday to Friday, then when I went to use it to go home, it didn't know it's position - I had gone out of the car park, down the long access road and a few miles down the road before it got it's position - about 10 minutes at a guess.
It also did it the other week - I went to a friends house for a few hours and when I came out, it took about 5 mins to get a fix.
When it's doing this, if you go into GPS Info, it's showing communication with the GPS (the little dotted line is moving) and it shows grey signal bars, but then about 10 minutes later it beeps, shows the N & W co-ordinates, compass and red signal bars.
--ian
lbendlin
PostPosted: Thu Jun 10, 2004 2:21 pm    Post subject: Reply with quote
For a good fix the visible sats need to be as far away from each other as possible. Since they are moving around constantly you cannot predict their constellation. t may well happen that they all line up, and even if you have a strong signal from each of them the information is useless and you can't get a fix.
After five minutes they should have moved enough to break out of the line and give better readings.
Lutz
The_Pilgrim
PostPosted: Sat Jun 12, 2004 9:36 am    Post subject: Reply with quote
I think you will get a quicker fix if you remain stationary.
i takes much longer if you start to drive.
The Pilgrim
jlw
PostPosted: Sat Jun 12, 2004 5:46 pm    Post subject: Reply with quote
A very cold start takes about 5 min... Have never lost my fix with the fortuna, always ~4-8 sats!
great device!
Fortuna Clip-On
CF: Lexar 256 MB
Poporta Alu-Case
22.055 (29 May 24)
