JohnWB Regular Visitor
Posted: Wed Sep 03, 2008 8:01 pm Post subject: MM 5 not sending overlays to PDA |
I am using MM 5.1.3 and have done a few routes on some 25,000 maps on the PC. I can export the map section to the PDA memory card & open the maps on the PDA with no problems, but the routes I produced do not show up. i have tried clicking the show all overlay button on the PDA & also copying the mmo file from the PC to the PDA but without success. The MM version says everything is ok on Help about on the PC. Is there something I am not doing or what, please help. |
AllyCat Frequent Visitor
Joined: Feb 23, 2005 Posts: 376 Location: Catford, London, UK
Posted: Wed Sep 03, 2008 8:19 pm Post subject: |
Hi John,
Did you use Mobile Device : Export Data to device.. (which is the "normal" way to transfer all Routes, Waypoints and Tracks to the PPC) ? Beware that this will send ALL the Overlay data within MM on your PC and may give the PPC indigestion.
The alternative method is to export a .mmo file (by right-clicking : Save As, on suitable items in the Map or Properties windows) and transfer to the PPC. Then open File Explorer on the PPC and tap on the .mmo file name. This should open MM (if necessary) and import the overlay data.
Cheers, Alan. _________________ Garmin GPS72H/76/60/45, Etrex H, Mapsource v6.5.
Acer N50,HP114,Loox N560,Dell x50,CF/SD cards to 4/32GB.
RoyalTek,Holux236,Navman B10 & Copilot(Globalsat) BT GPS,TomTom5/6.
Memory Map (v5.4.2 & v5.1.3 OS & Euro), GPS gate,OSGPSconverter. |
Posted: Wed Sep 03, 2008 8:45 pm Post subject: |
AllyCat wrote: | Hi John,
Cheers, Alan. |
Alan, that worked perfectly, if you were a girl I would kiss you, John |
Ianrweather Occasional Visitor
Joined: Feb 04, 2006 Posts: 9 Location: Staffordshire
Posted: Sat Sep 06, 2008 4:06 pm Post subject: Similar Problem |
I am also having problems transfering marks routes and tracks from Memory Map to a Road Angel, when I export to device it shows as incorrect version on the Road Angel, and then deletes all existing marks etc on the device.
I am not too clever on PCs any ideas or suggestions
Memory Map is version 5.27
Thanks Ian |
rothers Regular Visitor
Posted: Sat Sep 06, 2008 7:11 pm Post subject: |
Ian,
I suspect you need to upgrade the Memory Map software on your Road Angel. Memory Map overlays are not backwards compatible, you need at least 5.2.7 on your RA7000 (that's what I have on mine)
You'll need to get this from Memory Map support as Road Angel themselves only have 5.2.0 for download for some strange reason.
Neil |
Posted: Sat Sep 06, 2008 9:44 pm Post subject: |
Thanks for the info Neil, I have only just purchased it this week, the version on it is 5.2.1 so that is a bit dissapointing, how easy is it to update?
Thanks Ian. |
Posted: Sat Sep 06, 2008 10:38 pm Post subject: |
It's really just a case of copying the new files onto the SD card and overwriting the old files, then reset the RA7000.
5.2.7 contains a rather nice on screen keyboard
The files were made available for free download from the Memory Map website, unfortunately the URL was on the Memory Map forum which has been down for a few months now.
I'd give Memory Map support a ring on Monday.
Neil |
Posted: Sun Sep 07, 2008 11:39 pm Post subject: |
Thanks for that Neil I will get onto them Monday. |
Posted: Wed Sep 10, 2008 11:11 pm Post subject: Update |
Emailed Memory Map Technical, received email back with latest software attached, loaded on to Road Angel now transfers routes with no problem.
Big thanks to Neil for telling me what the problem was,
Big thanks to Memory Map for sending me the update. |
Brian Regular Visitor
Joined: Nov 12, 2003 Posts: 94 Location: Lancashire, England, Great Britain
