Thermocline Occasional Visitor
Joined: Apr 20, 2008 Posts: 12 Location: Helensburgh, Scotland
Posted: Sun May 18, 2008 10:44 am Post subject: Lost my voice |
Hi All
Just wondering if anyone else has this problem. I've had my TT720 for a few weeks and sometimes after it has been connected with TT Home and re-started, I find that there's a message about the chosen voice not being available. I have been using the standard voice (Kate) and there are no odd-balls installed. All I have to do to get around the problem is to re-select Kate as the voice and go through a couple of options screens. Not that big a problem, just a nuisance. Anyone know why this happens or what can be done to stop it ?
Cheers |
hijacker Regular Visitor
Posted: Sun May 18, 2008 11:01 am Post subject: |
I'm having the same issue with my 930 and using "Kate", the text to speech voice. _________________ TT GO 1005 |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sun May 18, 2008 2:31 pm Post subject: |
From deepest memory, it could be the settings.dat File in the Root of the Drive. Make sure it's not Read only.
Do you connect to the PC with the Device switched ON, or OFF?
Do you use Safely Disconnect? _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Sun May 18, 2008 2:57 pm Post subject: |
The Settings.dat file is set to Read/Write.
I connect to my PC with the device switched off and always use the Safe Disconnect function. _________________ TT GO 1005 |
sx50 Occasional Visitor
Posted: Thu Jul 03, 2008 11:54 pm Post subject: Re: Lost my voice |
Thermocline wrote: | Hi All
Cheers | have the exact same problem with my go 930 after connecting to home.
i lose voices and have to reselect the voice, it does not do it every time i connect, very strange???????
also there is no battery warning at all which is very annoying,it just turns off without warning. |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Fri Jul 04, 2008 1:24 am Post subject: |
It's a known bug in Home's software that, when you use the emulator (Operate My Go), you lose the computer voice setting? Want to know why? The answer is in the ttgo.bif file (it's a text file) in the map folder on your unit. Look at the defaultvoicename line. That's right. Home's software sets it every time to 'Nelson'! Well, since the unit can't find that name as your selection when you turn the machine on, you have to reset it .... again  |
sven1 Regular Visitor
Joined: Jun 26, 2005 Posts: 131 Location: Norwich, U.K
Posted: Fri Jul 04, 2008 8:38 am Post subject: |
dhn wrote: | It's a known bug in Home's software that, when you use the emulator (Operate My Go), you lose the computer voice setting? Want to know why? The answer is in the ttgo.bif file (it's a text file) in the map folder on your unit. Look at the defaultvoicename line. That's right. Home's software sets it every time to 'Nelson'! Well, since the unit can't find that name as your selection when you turn the machine on, you have to reset it .... again  |
can you not edit the file then to change default?
Jon |
Posted: Fri Jul 04, 2008 2:46 pm Post subject: |
You would think so, wouldn't you? But one member of another forum tried that and somehow the core code of Home changed it back. Just sloppy coding ... |
gearloos Occasional Visitor
Posted: Sat Jul 05, 2008 4:15 am Post subject: 930 also DID that...not anymore |
--Thanks! |
