MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15330 Location: Bradford, West Yorkshire
Posted: Tue Jul 01, 2008 9:50 am Post subject: |
carphead wrote: | Copy the pocketgps_uk_masters_and_pmobile.csv file to the SD Card and rename it speedcam.txt in the \SpeedCam folder. |
does it need to be called 'speedcam.txt' or will it work left as it is?
i was under the impression it would work as-is.
MaFt |
spider240366 Occasional Visitor
![](modules/Forums/images/avatars/gallery/garmin.jpg)
Posted: Wed Jul 02, 2008 10:22 am Post subject: speedcam for n95 |
just to let every 1 know.....ive installed the programe..got all the apps signed on symbian web site........they replied within 3 mins with the links to download the apps which installed straight away.......then downloaded the camera file from pocket gps.....put that on the sd card and change name to speedcam.txt and away it went...........works a treat .......................you do seem to have the need of a pucker email address thou..........not.hotmail or those types...........i used my home broadband address.......... ![Laughing](modules/Forums/images/smiles/icon_lol.gif) |
chris73 Occasional Visitor
Posted: Thu Jul 03, 2008 9:19 pm Post subject: success! |
Thankyou to everyone for their advice - finally had success. Left it for a week and it happened easily! |
nilesh Occasional Visitor
Posted: Thu Jul 03, 2008 11:52 pm Post subject: |
Iusw
I tried naming the csv file but it didnt work. it throws up a message stating that speed cam data not found. Do you need to rename both the files?
How can two files have the same name.
Nilesh |
WLMOATE Regular Visitor
![](modules/Forums/images/avatars/gallery/familyguy8.jpg)
Posted: Fri Jul 04, 2008 3:30 pm Post subject: |
Nilesh
Not telling you how to suck eggs, but have you renamed it speedcam.txt but accidently left the file as a .CSV type so your file is called speedcam.txt.csv? _________________ Wayne
MY-SOS, Benefon TWIG, DriveSmart, Wayfinder |
Posted: Fri Jul 04, 2008 4:09 pm Post subject: |
WLMOATE wrote: | Nilesh
Not telling you how to suck eggs, but have you renamed it speedcam.txt but accidently left the file as a .CSV type so your file is called speedcam.txt.csv? |
Hi Thanks for your reply....
I have solved the issue now. Yes I did rename it as speedcam.txt but I renamed it on my desktop and then copied it. it didnt work. then I tried renaming it on my E90 and it started working..
Nilesh |
pipwhaley Occasional Visitor
Posted: Tue Jul 08, 2008 11:48 pm Post subject: |
Please show me the sucking eggs thing. How do I change the file type from .csv to .txt?
Cheers. |
Posted: Wed Jul 09, 2008 10:01 am Post subject: |
pipwhaley wrote: | WLMOATE wrote: | Nilesh
Cheers. |
in windows, open up a folder (window) then at the top click 'Tools' then 'Folder Options...'
click the 'View' tab. about the 10th option down make sure that there is no tick next to 'Hide extensions for known file types'.
you should then see the '.csv' at the end of the filename. simply change this part to '.txt' by right-clicking and selecting 'rename'
if it NEEDS to be called speedcam.txt then i can make it so it downloads as that but i'm still waiting for confirmation! |
Posted: Wed Jul 09, 2008 11:13 am Post subject: |
MaFt wrote: | pipwhaley wrote: | WLMOATE wrote: | Nilesh
Cheers. |
Excellent! Thanks very much. I was nearly going to buy a satnav cos I thought the N95 wasn't functional enough for the job. But with all the new updates and this speedcam program its certainly looking like its up to the job.
Phil |
Posted: Wed Jul 09, 2008 1:31 pm Post subject: |
Ok now I have the speedcam working but when I switch from speedcam to maps and visversa it cancels the other one out. I re-loaded appswitch but it's still doing it.
Please help,
Phil.
**Update**
I've tried leaving the backlight on and switching the phone off and starting from the beginning with the 2 programs. Its behaving better now but If do anything on the phone the speedcam can cancel itself off. |
Posted: Wed Jul 09, 2008 11:53 pm Post subject: |
files should now download as .txt files. you will still need to rename to 'speedcam' though
MaFt |
b00by Occasional Visitor
Posted: Tue Oct 28, 2008 10:01 am Post subject: Nokia E71 and Speedcam |
I have a Nokia E71 and have downloaded Speedcam, the camera data file and python and loaded all. The Speedcam loads up and can switch with Nokia Maps by double clicking green (answer) button, but I cannot get the speedcam to overlay with maps. Unfortunately none of the buttons stated to operate the programme work with the E71. For instance clicking C doesnt work and when I press backspace it zooms the map in and out. I therefore assume the programme does not work as yet with the Nokia E71. Anyone else have the same problem? |
khack1 Occasional Visitor
Posted: Fri Nov 21, 2008 12:20 am Post subject: |
I have Nokia Maps 2.0 with speedcam, but have the same problem with it not swapping between the two. The speedcam overlay works in Maps, but it hides all the useful information about distance, speed and time to destination. If I put speedcam in the background, no alert sounds and there is no pop up overlay. Any suggestions? |
Kritou Lifetime Member
Posted: Thu Nov 27, 2008 2:40 pm Post subject: |
Does speedcam.txt have to be on the phone or card? |
Posted: Thu Nov 27, 2008 2:59 pm Post subject: |
If Maps is not running and SpeedCam is in the background will there be audio warnings for cameras (and will they also be output through the audio out jack)? |
