dsouter Occasional Visitor
Posted: Mon Jun 30, 2008 7:25 pm Post subject: |
I find the remote very useful when travelling. Simple to operate while still keeping eyes on the road. Safer than stretching any day.Duncan _________________ never mind eh!!!
go 1005 |
HummerUK Frequent Visitor
Joined: Apr 21, 2007 Posts: 332 Location: East Sussex
Posted: Sun Jul 06, 2008 4:45 pm Post subject: |
After a reset of my 520 I can no longer get my BT remote to pair
HummerUK |
Posted: Sun Jul 06, 2008 4:59 pm Post subject: |
Make sure the Blue LED illuminates on the remote and it might be an idea to put new batteries in (good luck with opening it), make sure Bluetooth is enabled on the TomTom and press a button for a few seconds, it will take a while for the unit to see the device but it should still work folloing a reset - Mike |
Posted: Sun Jul 06, 2008 5:04 pm Post subject: |
After a press of the reset button on the base of my 520, waiting a bit, power on and then tried a button on the remote it came up with the message to pair device.
Perhaps it only looks for new ones after a cold boot of the TT operating system?
Many thanks for the tips
HummerUK |
MadBaz Occasional Visitor
Posted: Wed Jul 23, 2008 1:29 pm Post subject: |
I keep the remote for my Go910 in my car door pocket and find it very useful for adjusting the volume.
I've never bothered working out what the other buttons do. |
DennisN Tired Old Man
Posted: Wed Jul 23, 2008 9:22 pm Post subject: |
MadBaz wrote: | I keep the remote for my Go910 in my car door pocket and find it very useful for adjusting the volume.
You DID say the 910 - that's a wireless remote, whereas the one here is Bluetooth.
No matter. It's pretty damn good, give it a try. The centre button is the equivalent of a tap on the screen, the up, down, left right presses move the selection accordingly, the bottom right nodule would bring up the Details menu, bottom left would then select the Details view, bottom right would be Done, bottom centre is for the occasions when there's a bottom centre button to press. The centre button is "OK", or "Enter" when you're doing something with it. You can operate the 910 completely without tapping the screen, which is pretty handy if it's a long arm's length away, or if you sometimes hit the wrong icon with a wobbly finger. I used mine all the time when I had a GO700 and wouldn't be without it.
You really are missing a trick if you don't give it a try. _________________ Dennis
Two of them are obesiting!! |
Posted: Wed Jul 23, 2008 10:36 pm Post subject: |
To be honest I find the old RF remote from the x10 range a better device, it is more responsive in use - you can also use it to "play" with adjacent cars navs units when stuck in traffic (not that I would ever do such a thing).
The BT remote takes much longer to sync to the device, and once locked to a unit it can only control the single device - Mike |
Posted: Wed Jul 23, 2008 10:51 pm Post subject: |
There you go. Mike's dislikes are my favourites - I couldn't use the RF remote when I had more than one device in the van, whereas the new one will only affect the device I've linked it to. I never did manage to play with anybody else's (and I did try, you west of the pennines hypocrite!!). The one better feature with the RF remote was map scrolling - that is a VERY sad loss on the Bluetooth one. And, unlike Mike, I find the BT one more responsive and reliable at sending instructions.
Just goes to show, you'll probably always get two sides (at least) with every recommendation!! _________________ Dennis
PaulBt Lifetime Member
Joined: Sep 22, 2006 Posts: 188 Location: Kempsford, UK
Posted: Wed Jul 23, 2008 11:09 pm Post subject: How long are your batteries lasting? |
I am on my third set of batteries, and have only used the device on an actual trip once. As every other time I've gone to use it, it has not responded, and when I changed the batteries it works again.
I like the unit and particularly like the one press to pause the audio, but have only been able to testing at home as it has always been flat in the car.
Is it trying to connect the a bluetooth device or is it getting pressed all the time in the car? I have tried to place it where it should not be getting press all the time.
Any ideas? _________________ TT720 V8.010, regular audio book user.
WestEuro v805 connected to E90 on O2
TT910 V6.525, TTN5, TTN3, TT on Psion 5mx |
benjamino Occasional Visitor
Posted: Thu Jan 29, 2009 12:27 pm Post subject: Accessing the quick menu |
Just to say you can also use the remote to access the Quick Menu if you have it enabled and set up. Just hold down the central of the 3 raised buttons. (pressing it normally plays or pauses the music) - Must say I'm relieved to discover this as wasn't expecting it be possible after reading the review  |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2146 Location: Surrounded by A1, M1 & M25
Posted: Thu Jan 29, 2009 12:33 pm Post subject: |
If you hold down the central push button in the "joypad" in the x40 range it activates the voice command. _________________ Drivelux |
Belgarath Occasional Visitor
Posted: Fri Jan 30, 2009 3:44 pm Post subject: |
Can the bluetooth remote be set up (with a 940) so that it can forward to the next music track with one press (without going through the menus).
Chrs. |
Posted: Fri Jan 30, 2009 4:03 pm Post subject: |
Belgarath wrote: | Can the bluetooth remote be set up (with a 940) so that it can forward to the next music track with one press (without going through the menus). | Yes it does this as supplied there is no setting up required - Mike |
Posted: Fri Jan 30, 2009 4:05 pm Post subject: |
Yeah the remote has dedicated buttons for next track and previous track when in the main map mode. Works on the 530 anyway but think it is a standard feature. |
Posted: Fri Jan 30, 2009 6:32 pm Post subject: |
Excellent. Thanks.
Does the remote come with a mount/holder like the 910 did? I noticed on a advert for the garmin they had something similar that fitted actually on the wheel that you could press with your thumb without your hands leaving the wheel. A solution like that would be neat.
What are people's preferred MO for using the remote? Do you have it mounted on the dash somewhere near the steering wheel, or on the seat next to them or some cubbyhole nearby? |
