Pocket GPS World :: View topic - Problem With Origion B2 Laser Modual
JamesJamz
PostPosted: Sun Feb 17, 2008 9:07 am    Post subject: Problem With Origion B2 Laser Modual Reply with quote
Alright Everyone,
Im having a problem with my B2 ATM.... The unit works fine when the laser modual isnt plugged in, but as soon as you plug it in, and activate it, the unit restarts all the time, gets to the boot screen and restarts again.
Anyone else had this problem, and know how to get around it?
James
MrTee
PostPosted: Fri Mar 14, 2008 10:10 am    Post subject: Re: Problem With Origion B2 Laser Modual Reply with quote
Hi James,
The problem you have can be one of several. Without actually seeing the device it's difficult to diagnose. Do you use the laser detector inside the car (some people use them externally & water ingress occurs). The problem could also be with the cradle/loom. Do you know anyone else that has a OB2?, if so just swap the two units to see what happens on the other cradle. Finally, perform a reset of the unit. open the Origin Update Utility (V1.33); Click FILE, then INITIALIZE REMOTE.
Regards Dave T.
Ex-Origin Technincal Product Support Manager.
PS - Comments about the database. It is without question the best DB in the UK at this time.
JamesJamz wrote:
Alright Everyone,
James
JamesJamz
PostPosted: Fri Mar 14, 2008 11:59 am    Post subject: Reply with quote
Thanks for the reply!
I think it may actually be the cradle in the car, but cannot be sure... The problem seems to have got worse now.
When you put the B2 on the in car cradle, the start up procedure runs and when it gets to the end the red lights come on beep and the unit restarts again in a constant loop!
The unit is fine when its on the USB cradle....
Is it the connections on the car cradle? or something else?
JamesJamz
PS. I did try contacting Pogo about the device, but i have not receved any responce
DenzB
PostPosted: Fri Mar 14, 2008 10:36 pm    Post subject: Reply with quote
Hi James,
Had a similar thing happen to me, have you tried to e-mail origin?
Seemed to work for me.
Sent mine back under warranty and repaired foc.
Regards Denz
JamesJamz
PostPosted: Sat Mar 15, 2008 7:01 pm    Post subject: Reply with quote
Yea i tried to email them... twice now, and no reply in a few weeks.
My origin is second hand and i think its over 2 years old... so its well out of the garantee period.
