Pocket GPS World :: View topic - icon/facility missing
chrisn5004
PostPosted: Mon Feb 04, 2008 8:45 am    Post subject: icon/facility missing Reply with quote
having just upgraded to latest software/map/postcodes/speed cams on my go300 ive noticed that the "lifering" icon and the where am i facility has gone! (wife found it very useful) any ideas on what happened to it and is it possible to get it back?
thanks in advance
PostPosted: Mon Feb 04, 2008 9:50 am    Post subject: Reply with quote
Are you using a Custom Menu?
If yes then you need to rename the SdkRegistry, or remove it.
If not, then have you tried a Reset?
chrisn5004
PostPosted: Mon Feb 04, 2008 10:55 am    Post subject: no Reply with quote
no im not using a custom menu and ive tried your suggestion of a reset but still not there you mentioned renaming or deleting a file will that cause any damage ? if not what does it do exactly. im still trying to learn all this Smile
dhn
PostPosted: Mon Feb 04, 2008 1:11 pm    Post subject: Re: no Reply with quote
Does your model have the preference option to show more menus / fewer menus? If so, do you have it set for fewer?
Daggers
PostPosted: Mon Feb 04, 2008 1:34 pm    Post subject: Reply with quote
SDKregistry is a folder that can contain external/3rd party applications, not provided by TomTom. If you've ever used SunTime, Quickam, or any of the other additional programs, then you may have an SDKregistry lying around!
PostPosted: Mon Feb 04, 2008 3:06 pm    Post subject: Reply with quote
As Daggers has explained, we need you to dock you GO and look at the file list on the device. if you see a folder called SDKregistry then we know that you have installed software at some point that has modified the menu structure.
If you have it's a simple fix, let us know what you discover?
chrisn5004
PostPosted: Mon Feb 04, 2008 3:46 pm    Post subject: we're getting somewhere :) Reply with quote
yes i have a folder called sdkregistry and looking in it it has the files for poi capture, from earlier posts should i just rename the folder? to "poicapture" or some such more helpful name, will that sort the problem?
thanks for all your help and input it's much appreciated
PostPosted: Mon Feb 04, 2008 3:50 pm    Post subject: Reply with quote
Simply resolved. POICapture is no lonfer supported anyway as TomTom withdrew SDK support.
You should uninstall POICapture by deleting the SDKRegistry and POICapture folders then reboot.
That should cure things Smile
PostPosted: Mon Feb 04, 2008 4:05 pm    Post subject: Reply with quote
Doh!!!
I've just spent 10 minutes wondering what "lifering" could be a typo for! (or even worse, what a lifer did on a TomTom).
Time for a lie-down!
PostPosted: Mon Feb 04, 2008 5:02 pm    Post subject: Reply with quote
Don't be too hard on yourself, my first reply suggested that Where Am I was in the HelpMenu and asked what a 'lifering' icon was.
Only after I posted it did I realise it was the Icon for HelpMe i.e. a 'Life Ring'!!
Thankfully a swift edit saved the day Wink
chrisn5004
PostPosted: Mon Feb 04, 2008 5:17 pm    Post subject: thanks again Reply with quote
thanks to you all i'll let you know if it resolved the problem when my GO300 returns shortly it's out at the moment testing speed cameras with my son.... thanks again
chrisn5004
PostPosted: Tue Feb 05, 2008 9:00 am    Post subject: many thanks Reply with quote
that solution worked fine all is back to normal (ish) you've all been a great help and i hope i can be of use to someone on the forum at some time
22.055 (29 May 24)
