xboxhaxorz Occasional Visitor
Posted: Wed Jul 18, 2007 11:28 pm Post subject: GPSlim 236 does not function anymore doesnt turn on |
I have been using my gps for a while now. Recently my battery died, so i plugged it into the car charger and turned it on but it did not work. So when i came home i charged it and turned it on. The red light flashes really fast when turned on and thats it. When i charge it the green light comes on, i am not sure why the unit has started doing this.
Basically the unit doesnt turn on. I charged a nokia battery and then put it inside and it did the same exact thing. |
Posted: Wed Jul 18, 2007 11:33 pm Post subject: |
Do you get the same result when the GPSlim is not connected to the charge cable? Some charge cables are not correctly wired for the 236.
Charge it up with the device switched off
Unplug it and switch it on, the Blue LED should flash, the orange LED will be steady until you get a position fix, at which point it will flash.
If the device doesn't behave as above take the battery out for 40 to 72 hours before trying again (this action will deplete the other internal battery and reset the device) - Mike |
Posted: Wed Jul 18, 2007 11:43 pm Post subject: |
i tried charging it with the included charger and it charges for a bit then turns off, i tried this a few times i even connected to my usb cord on my pc and it did the same thing.
im not sure which position is on/off on the device
when i put it in the up position which the case lables as ON it doesnt do anything, when i put it down it flashes red for a 1/2 a sec. the case has a pic of the power logo for the bottom position. please let me know which is on/off.
thanks
edit: i just put it in the main wall charger and the green light came on for a 1/2 sec and then off doesnt appear to be charging at all |
Posted: Thu Jul 19, 2007 8:15 am Post subject: |
With the device in front of the switch should be on the left side of the device the USB socket and LEDs will be at the end of the device facing you:
Pushing the switch away from you is the ON position.
Pulling the switch towards you is the off position.
If the green light is only flashing for a second or two it is indicative of the battery being fully charged. When the device is not plugged into a charger and switched on the Blue (center LED) should illuminate constantly for about 5 seconds before starting to flash, the Amber LED illuminates approx two seconds after switch on, this will illuminate constantly until the device has attained a position fix at which point it to will flash. - Mike |
Posted: Wed Aug 01, 2007 9:56 pm Post subject: |
Thanks for the tips. I have tried these recommended steps 2 times and it still does the same thing. |
Posted: Tue Aug 07, 2007 4:50 am Post subject: |
can anybody advise me on something i can do now that i have tried those steps with no luck |
Posted: Tue Aug 07, 2007 7:10 am Post subject: |
No Blue LED when it is switched on? - it sounds like its died to me, when and where did you get it from its possible it might still be covered under waranty - Mike |
Posted: Tue Aug 07, 2007 9:36 pm Post subject: |
i got it about 8mths ago from ebay
i tried calling the #s on the manual but they dont work at all |
