ccsnet Regular Visitor
Posted: Sat Sep 16, 2006 12:55 pm Post subject: ITS & Traffic Master TMC Frequencys ? |
Just playing with some PC software ( TMC enabled dont worry so I have licence and all that ) how ever I have some middleware to support it.
Any way - long and short of it I need to input the TMC FM Frequencys manually so can any one tell me the ITS on ( I think its just classic FM ) and the RAC Trafficmaster one ?
Terran _________________ http://www.letscommunicate.co.uk/carpc/ |
Posted: Sat Sep 16, 2006 1:17 pm Post subject: |
For Classic FM Frequencys have a look at THIS list - scroll down to see the full list!
If you need to see which transmitter is closer to where you live have a look at this MAP - Not too sure about the TM system, but I am sure a google will turn up some info - Mike |
swing Pocket GPS Verifier
Posted: Sat Sep 16, 2006 2:32 pm Post subject: |
The frequency varies from location to location (on both Classic FM and Trafficmaster) - but basically, if you can get a radio signal with TMC, and it's not Classic, it's Trafficmaster
Unfortunately, your profile does not state your location to allow me to try and guess the radio station (and hence frequency) of Trafficmaster in your area.
Out of interest, what software is it, and what middleware...? |
Posted: Sat Sep 16, 2006 6:44 pm Post subject: |
swing wrote: | The frequency varies from location to location (on both Classic FM and Trafficmaster) - but basically, if you can get a radio signal with TMC, and it's not Classic, it's Trafficmaster
Out of interest, what software is it, and what middleware...? | Morecambe Lancs is my location and its a bit of software called ShowGPS.com ;)
Posted: Sat Sep 16, 2006 6:55 pm Post subject: |
101.8FM should do for you in that area, but it is only a 10KW tx at that location (Morecombe Bay), although its North of your location - I can pick this tx up in Blackpool though, so you should be OK where you are - Mike |
Posted: Sun Sep 17, 2006 6:20 pm Post subject: |
mikealder wrote: | 101.8FM should do for you in that area, but it is only a 10KW tx at that location (Morecombe Bay), although its North of your location - I can pick this tx up in Blackpool though, so you should be OK where you are - Mike | Thanks for that... any idead which one will be the TM RAC transmission round here ? I was thinking Rock FM or the Bay... but not sure who owns them.
Posted: Mon Sep 18, 2006 12:28 pm Post subject: |
Rock is EMAP, so probably not them
The Bay is CN Group, so probably not them either
101.8 is the frequency for Classic FM
Certainly none of the radio stations from the Morecambe Bay seem to be independent (commercial) radio stations, so I suspect you'll need another radio station for Trafficmaster. Having done some searching though, I'm struggling to come up with an obvious radio station |
Posted: Mon Sep 18, 2006 2:06 pm Post subject: |
swing wrote: | Rock is EMAP, so probably not them
Certainly none of the radio stations from the Morecambe Bay seem to be independent (commercial) radio stations, so I suspect you'll need another radio station for Trafficmaster. Having done some searching though, I'm struggling to come up with an obvious radio station | Found this.... 100.4 looks liek a winner...
Also http://www.gcapmedia.com/index.php?id=3 may help others too.
Posted: Mon Sep 18, 2006 2:09 pm Post subject: |
ccsnet wrote: | swing wrote: | Rock is EMAP, so probably not them
Terran | Just noticed... gcapmedia.com owns Classic FM too.... I surley TMC from both services can't be running over the same carrier ?
Posted: Mon Sep 18, 2006 2:56 pm Post subject: |
iTIS Holdings use Classic FM, and only Classic FM.
Trafficmaster use the rest of the GCap Media stations and stations from Chrysalis as well.
You are right that one radio station cannot carry the TMC signal for both services, but one group of companies can |
gotom Occasional Visitor
Posted: Sat Dec 02, 2006 3:12 pm Post subject: rds-tmc with go910 works on heart and real too |
I have just bought my rds-tmc unit to use with my GO910. I have travelled from M1 J37 (Barnsley) to M1 J28 (Mansfield) and I can confirm that after my GO listened to Galaxy 105.6 for 10minutes with no Trafic data on my GO it eventually tuned to Real 106.2FM and I could see all traffic problems within about 100 mile radius on traffic screen - 73 problems. Near J29 of M1 GO switched automatically to Heart 106FM and I can still see all traffic issues in local area. I confirm my unit has never tuned to Classic FM. So is this proof that TMC data for GO is obtainable from other sources than Classic FM? I have a Go910 with v6.520 software and my RDS-TMC Unit is a 4V00.000 bought from Argos today. |
Posted: Sun Dec 03, 2006 11:17 am Post subject: |
I've seen a couple of people stating this, but I really can't see how it's happening - the two data suppliers are not compatible, and I can tell you the TomTom does not have the right information to decode the "other" traffic provider.
A number of things could explain what's going on:
1. The unit briefly tunes to Classic FM, gets the data and then retunes to the other station, giving you the impression it got the data from the other station.
2. iTIS have arranged for some small radio stations to offer "fill in" for areas of the country that Classic FM isn't good (although I've seen no official statement to this affect).
3. The TomTom is simply reporting the wrong name for Classic FM.
4. TomTom are moving over to Trafficmaster for the supply of their RDS-TMC service (again, something I've not seen an official statement on). |
