ffrr Occasional Visitor
Posted: Sun Nov 26, 2006 11:14 am Post subject: i3 sqawked and lost it's voice |
Sadly I think my i3 is done for. While using it, just as it started to give a direction to turn, it made a sqawking sound, and has been silent since then. I even hard reset it and cleared all data. No beeps, no voice, not even when changing the volume in settings.
Unless someone has an idea, I guess I'll soon be finding out how good the warranty is in Australia  |
paulyoung666 Occasional Visitor
Posted: Sun Nov 26, 2006 12:02 pm Post subject: |
have you tried fresh batteries or the usb powerlead ????? |
Posted: Sun Nov 26, 2006 1:25 pm Post subject: |
paulyoung666 wrote: | have you tried fresh batteries or the usb powerlead ????? |
Yes, it was running on the USB lead actually, when it died. |
Posted: Sun Nov 26, 2006 6:43 pm Post subject: |
Try switching the unit to another voice (note this can take some time) once complete try it out, then switch the voice back to the one you use normally. Go to Settings/ Language/ Voice Language - switch it to American English first then back to British English, unless you have a "Sheila" type installed - Mike |
Ash10 Pocket GPS Verifier
Posted: Sun Nov 26, 2006 9:15 pm Post subject: |
Try what has been suggested above - if that doesn't cure it, suspect a hardware fault and get onto Garmin. Their customer support is absolutely first-rate.
I've had two units fail like this - the first went all croaky over a week or so before failing completely, and the second went croaky and got replaced before it died altogether. |
Posted: Mon Nov 27, 2006 1:22 am Post subject: |
mikealder wrote: | Try switching the unit to another voice (note this can take some time) once complete try it out, then switch the voice back to the one you use normally. Go to Settings/ Language/ Voice Language - switch it to American English first then back to British English, unless you have a "Sheila" type installed - Mike |
I tried it, but unfortunately it didn't work.
btw: I quite liked the British voice :D |
Posted: Mon Nov 27, 2006 1:25 am Post subject: |
Ash10 wrote: | Try what has been suggested above - if that doesn't cure it, suspect a hardware fault and get onto Garmin. Their customer support is absolutely first-rate.
I just rang the store where I purchased it. As it failed, one day short of a month old, they will handle the warranty (probably just means they will send it back to Garmin for me)
I will send the rubber windscreen mount back as well, as it has started to perish and stick black bits of rubber to my windscreen already ! |
Posted: Mon Nov 27, 2006 9:57 am Post subject: |
Good news. They had a 30 day replacement warranty. I now have a new unit. |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Mon Nov 27, 2006 4:27 pm Post subject: |
ffrr wrote: | I will send the rubber windscreen mount back as well, as it has started to perish and stick black bits of rubber to my windscreen already ! |
Some people in the UK had a similar problem during the very hot weather (for us!) this summer.
Could you use the adhesive disc somewhere on the dash rather than putting the mount on the windscreen, where it obviously gets extremely hot? Or buy a separate mount system like the Brodit?
Pleased to hear they replaced the unit. :D _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Tue Nov 28, 2006 6:50 am Post subject: |
Anita wrote: | ffrr wrote: | I will send the rubber windscreen mount back as well, as it has started to perish and stick black bits of rubber to my windscreen already ! |
Pleased to hear they replaced the unit. :D |
I used some silicone rubber glue to attach the old one to my Windscreen, and for now it is very firmly attached (I didn't give it back with the faulty unit). If it let's go, I will have to find a better location, as you suggested. It does get VERY hot here at times, and we are just now heading into our hot season. |
Posted: Tue Nov 28, 2006 9:47 am Post subject: |
bad idea leaving the mount on show all the time , the police are warning specifically against doing this due to theft  |
mk_graham Regular Visitor
Joined: Jul 13, 2006 Posts: 200 Location: Milton Keynes UK
Posted: Tue Nov 28, 2006 2:29 pm Post subject: |
paulyoung666 wrote: | bad idea leaving the mount on show all the time , the police are warning specifically against doing this due to theft  | Not sure Australia has the same car crime problems as UK. _________________ Garmin i3 gone (sold on eBay)
V7 PMD 1400 with Western Europe Maps gone (sold in local paper)
TomTom Go 720 WE Maps (for sale)
iPhone with Sygic Mobile Maps (Europe) - having problems |
Posted: Wed Nov 29, 2006 7:18 am Post subject: |
mk_graham wrote: | paulyoung666 wrote: | bad idea leaving the mount on show all the time , the police are warning specifically against doing this due to theft  | Not sure Australia has the same car crime problems as UK. |
Luckily it isn't so bad, especially where I usually park. But it's getting worse, and there will come a day when we will be just as bad  |
