Pocket GPS World :: View topic - "here be dragons"- navigating to a map point?
Tinpusher
PostPosted: Fri Oct 20, 2006 7:22 pm    Post subject: "here be dragons"- navigating to a map point? Reply with quote
Is it possible to select a position from the map, and tell D6 to "navigate to" that point?
By the same token, is it possible to select a point on a map and add it as a favourite?
My mum lives in the middle of nowhere- the postcode isn't recognised and it's about 2/3 of the way along a minor road. I want to add her house into my favourites, and at the moment I can't figure out how to do it.
Home - Dell Axim X51 + BT359 + D6 & MM
Work - IGI CCNS4, Vexcel Ultracam D & Somag GSM3000, X-Treme L1/L2 GPS receiver all shoved into a Piper Chieftain, registration G-OSGB. See the results on http://local.live.com/
PostPosted: Fri Oct 20, 2006 11:38 pm    Post subject: Reply with quote
Most street routing programs will only allow POIs on or close to streets. You'll have to set the POI accordingly.
Report map errors to the map providers - only reporting will help to eventually improve the data.
Tinpusher
PostPosted: Fri Oct 20, 2006 11:48 pm    Post subject: Reply with quote
How about setting a POI from a lat/long position? How can I do this is D6?
barryd
PostPosted: Sat Oct 21, 2006 6:11 pm    Post subject: Reply with quote
Assuming you're using a Pocket PC, my free OS GPS Convertor utility will do it:
http://www.freenetpages.co.uk/hp/barrydavies/index.htm
Be warned that I have never used Destinator, but added in support for it at the request of a user on this forum about 18 months ago, who spent a fair bit of time getting it to work. If it doesn't work for your version of Destinator, I'd need your technical input to make it work!
Good luck
Barry Davies
barryd
PostPosted: Sat Oct 21, 2006 6:17 pm    Post subject: Reply with quote
See this topic for more info:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=25252&highlight=osgps
Barry Davies
Tinpusher
PostPosted: Sun Oct 22, 2006 12:02 pm    Post subject: Reply with quote
Thanks Barry, that looks like exactly the sort of thing I'm after. I'll let you know how I get on so you can get some feedback as to how it works in D6.
MarkP
PostPosted: Mon Oct 23, 2006 1:47 pm    Post subject: Re: "here be dragons"- navigating to a map point? Reply with quote
You can tap on a point on the map whilst navigating and a window pops up with "Go there", "Add to favourites" and something else which I can't remember. Wouldn't that serve your needs?
23.053 (21 May 25)
