Pocket GPS World :: View topic - TomTom RDS-TMC Traffic Receiver Available In Europe
Goto page Previous  1, 2, 3, 4, 5 ... 20, 21, 22  Next
iancjc
PostPosted: Wed Oct 11, 2006 1:36 am    Post subject: Reply with quote
is the tmc data any different from the gprs data?
I've been using traffic for the past 18 months and finally the gprs data is reliable and mostly upto date - does gprs use the same data -
I' m not sure I'd be happy about the regional data on tmc though, I often do a 220 mile drive upto Lancashire and have the choice of A1 M62 or A14 M6 M62 (only about 10 miles in it either way) and would be gutted not to get details of problems further into my journey as that would completely change my route...
TTN6.03 tomtom 7.xx (one)
mwfox
PostPosted: Wed Oct 11, 2006 10:06 am    Post subject: Reply with quote
I think the GPRS data will be the same as the TMC data - both from Itis.
Can someone else confirm if they only get regional traffic information as well - I would have thought the same data would have been broadcast nationally.
etlsngd
PostPosted: Wed Oct 11, 2006 11:27 am    Post subject: Reply with quote
I asked the same question to Tomtom and they replied by pointing me to the following:
http://www.tomtom.com/page.php?Page=rds-tmc
Doesn't completely answer the question, I interpret it as the 2 offer basically the same information w.r.t traffic from itis, by tomtom refer the their plus service as more "accurate" and "high performance" although when you look at the details. I think this means that you can get extra info like wetaher and read condition, which is pretty useless really as I find the best way of checking weather and road conditions is to look out of the window....clearly they are lookig at differentiating their service to justify ongoing yearly subscription..
/Steve
duckie008
PostPosted: Wed Oct 11, 2006 1:29 pm    Post subject: Reply with quote
i've started a new thread under "RDS-TMC Traffic or TomTom Traffic" (in the UK) for your opinions on both services as this thread was originally about the receiver being available in Europe, etc
coastersteve
PostPosted: Wed Oct 11, 2006 2:25 pm    Post subject: Reply with quote
I've just had mine arrive from Easy devices, just need the 910 back from TT because it wouldn't charge Crying or Very sad
mwfox
PostPosted: Wed Oct 11, 2006 4:51 pm    Post subject: Reply with quote
Do people get disconnections from the TMC receiver when the mount disconnects on the x10 series? (I didn't think the new mount cured this problem - the software update hid the problem).
jamiepyoung
PostPosted: Wed Oct 11, 2006 8:05 pm    Post subject: Reply with quote
OK, second day of trying: over the space of an hour it tuned in to various stations (never classic), but i got no traffic info.
help!!
(i've still got the old mount - could it be that?)
jamiepyoung wrote:
ok, what am i doing wrong???
plugged the new tmc receiver in, its recognised etc.
selected uk
it eventually found radio 2 and 3, but lost these after a while.
in a 1 hour journey, i got no info.
i had the aerial stretched out (about 75% of it).
help.....
lydiachris
PostPosted: Wed Oct 11, 2006 10:14 pm    Post subject: Reply with quote
Nothing to do with the mount.
just MAKE SURE you have straightened out the cable as much as possible and selected, under tmc country, "Strongest Signal" I've found this is much more reliable and tends to lock onto radio 4 and classic fm quite a lot.
I've found when you select "United Kingdom" it seems to hunt down the local stations first then if that fails, it will lock onto the regional ones.
This is what your experiencing with the dropping out of the signal. Hope this helps.
lydiachris
TonyHoyle
PostPosted: Thu Oct 12, 2006 1:22 am    Post subject: Reply with quote
If it's locking into Radio 4 it is not working. Radio 4 does not broadcast TMC.
Seems to be a common fault with this device... TT are going to have to do an update quick or get a lot of returns I suspect.
jamiepyoung
PostPosted: Thu Oct 12, 2006 10:06 am    Post subject: Reply with quote
yay!
it worked this morning - put it on strongest signal as recommended above and eventually picked up classic.
it didn't pick up any delays on my route, so i thought it wasn't working (i travel M40 - M42 - M5 - M6 - M54 every day to work) - but, it was only only flipping correct! a clear run for the first time in weeks!
it did pick up delays on the other carriageway, so it was working.
the only negative, it took about 20 minutes to find classic and get reports - given that this was the first time it has found it, will it be quicker next time (now that it knows the frequency)??
mwfox
PostPosted: Thu Oct 12, 2006 4:00 pm    Post subject: Reply with quote
Tomtom say
"The TMC receiver gives traffic information for the whole UK at one time"
So does not divide the info into regions.
lydiachris
PostPosted: Thu Oct 12, 2006 4:53 pm    Post subject: Reply with quote
Well thats a load of rubbish.
When in the norfolk area, I can get traffic info ONLY for roughly a 150 mile radius.
Can someone else with the tmc receiver, go to "traffic" then "Browse Map" then zoom out and see how far their red dots expand to when hooked to classic FM.
Another question of mine, when radio eventually becomes digital, will our tmc receivers stop working??!! 8O
jamiepyoung
PostPosted: Thu Oct 12, 2006 4:57 pm    Post subject: Reply with quote
lydiachris, how long does yours take now to start colleccting traffic info from start up?
lydiachris
PostPosted: Thu Oct 12, 2006 5:02 pm    Post subject: Reply with quote
About a minute why??!!
lydiachris
PostPosted: Thu Oct 12, 2006 5:04 pm    Post subject: Reply with quote
Have you all seen this:
Read the small points at the bottom
Page 4 of 22
