Pocket GPS World :: View topic - I3 firmware 3.20
I3 firmware 3.20
Goto page Previous  1, 2, 3 ... 7, 8, 9 ... 12, 13, 14  Next
mars.1
PostPosted: Tue Sep 26, 2006 3:21 pm    Post subject: Reply with quote
Let me just point out that i never upgraded to versions 3.0 or 3.10 when they was released. Is this the reason why my unit works on filmware 3.20.
Lester_Burnham
PostPosted: Tue Sep 26, 2006 3:27 pm    Post subject: Reply with quote
Well conventional wisdom says it shouldn't make any difference.
However, it's rather hard to ignore the numerous, anecdotal accounts in here, that suggest that the buggy firmware versions do, in some odd way, permanently "tattoo" the i3s.
trevf
PostPosted: Tue Sep 26, 2006 4:09 pm    Post subject: Reply with quote
Sorry guys, I have 3.10 then 3.20 and no problems. I think the issue is that we all think that there are 2 models of i3, those with internal Maps, and those without. Reading through all of the posts I think there are at least 4 (possibly more). Those with Internal Maps that work on Newer Firmware, Those without Internal Maps that work on Newer Firmware, then the same again that don't work on Newer Firmware (by newer firmware I mean anything higher than 2.82 Beta).
I'm not sure how to prove this though, is there a hidden model number or part number or something that we can compare?
Garmin i3
Firmware 3.4
Almahadeus
PostPosted: Tue Sep 26, 2006 5:34 pm    Post subject: Reply with quote
Also people seem to be confusing units that come with transflash WITHOUT maps (maps installed on internal memory) with units with a transflash card WITH the maps installed on the card itself.
Reading through these posts it seems that units with the MAPS ON THE TF CARD (will have audio version 2.0) are suffering with the software bug.
nitelife
PostPosted: Tue Sep 26, 2006 5:57 pm    Post subject: Reply with quote
No, mine has internal memory and maps on the card, and seems to be fine so far.
I know the maps are on the card because if I take it out it prompts me to put it back in, and I know I have internal memory because I can write to it using poiloader.
It has audio 2.5 as well.
Almahadeus
PostPosted: Tue Sep 26, 2006 7:45 pm    Post subject: Reply with quote
You see my point about the confusion. Your i3 CAN NOT have the maps on the card and at the same time have audio version 2.5. The highest the audio version can go to on the units where the maps are on the card is 2.0. Your unit has the maps on the internal memory (the newer version of the i3). See here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=46240&start=0
typan
PostPosted: Tue Sep 26, 2006 8:02 pm    Post subject: Reply with quote
Well mine has maps on internal memory so is the newer version and poi's on card, this was my first upgrade from 2.70 and it didn't like it. I can't see any pattern as to why some work and others don't. Confused
nitelife
PostPosted: Tue Sep 26, 2006 10:57 pm    Post subject: Reply with quote
Hey,
I dont want to start an argument, but I can prove it.
1. POI Loader gives me two options, the I3 and the card reader connected to my pc (not definite proof but read on)
2. If I take the card out and turn on the i3 it tells me to load maps onto it (meaning the maps are NOT on internal memory).
3. The about page definitely says audio version 2.5.
Ive taken some screenshots to show you (sorry about the bad quality, went a bit too close in macro mode)
snowboardcriminal
PostPosted: Tue Sep 26, 2006 11:06 pm    Post subject: Reply with quote
Have to agree with Nitelife, i have also removed the card and am prompted to load maps, but i can still load poi's to internal memory, put the card back in and eh voila, all working as it should, and audio version 2.50.
Now also running FW 3.20 no problems so far and much improved searching for poi's.
Incidentally mine was originally destined for the French market as when registered with garmin it says so, but only bought 1 month ago.
Don't eat yellow snow
i3, on the middle of the dash, works just fine!
There are things that I know and you don't know, there are things that you know that i don't know, but always remember there is much that we both don't know.
timber
PostPosted: Tue Sep 26, 2006 11:17 pm    Post subject: Reply with quote
here is some software that will take screenshots of your device, you can also use it to write a modified/customised splash screen to the unit Wink
http://www.garmin.com/support/download_details.jsp?id=545
zogman
PostPosted: Wed Sep 27, 2006 9:59 am    Post subject: Reply with quote
Almahadeus, sorry mate you're wrong...i to have mapping on the card and audio version 2.5...and having had problems with v3.20 i went back to v2.7, still retaining audio v2.5.......
nitelife
PostPosted: Wed Sep 27, 2006 10:36 am    Post subject: Reply with quote
Excellent! I wondered how people in other threads got perfect pictures :D
Thanks. Embarassed
PaulB2005
PostPosted: Wed Sep 27, 2006 12:28 pm    Post subject: Reply with quote
Going back to 2.7 to see if i'm imagining the lag in map mode.....
Coaster2
PostPosted: Wed Sep 27, 2006 2:40 pm    Post subject: Reply with quote
I've tried all versions from 2.7 and have always gone back to 2.7.
Upgraded to 3.2 last week and, when I first used it, thought 'back to 2.7 again'.
I had the map freezing, the speedo freezing and the only way to get it going again was to switch off and restart. Was also getting 'low battery' warning so I wondered if that could be the problem.
Recharged the batteries and, since then have had no problems at all apart from the odd slow map update but no worse than 2.7. I shall now be sticking to 3.2. (for the time being :D )
suby786
PostPosted: Wed Sep 27, 2006 2:58 pm    Post subject: Reply with quote
yeh ive noticed that 2
i was on 2.70 and now i upgraded to 3.20,
in map mode, it either works REALLLLY WELLL or it locks in 1 position sometiomes when im far up the road, pressing back and reloadin VIEW MAP unlocks it, but it can be annoying, but at most times it works really good
also in nav mode, when u press start navigating, the screen goes white (after its 100% routed), the directions at top are accurate but it takes a change in the map route for it not to be white. (3d mode)
i.e. if im on a roundabout when it reaches 100%, it will stay white until the next instruction, i.e. coming off the roundabout
this didnt use 2 happen on 2.70
has any1 else experienced this?
Page 8 of 14
22.062 (12 Jun 24)
