Pocket GPS World :: View topic - TomTom Version v6.15 Firmware Update for pre x10 AIO's
Goto page Previous  1, 2, 3, 4, 5, 6  Next
gadget_sa
PostPosted: Wed Aug 09, 2006 7:10 pm    Post subject: Re: Ray's extended warnings on this latest 6.15 version Reply with quote
pip510 wrote:
id wrote:
Has any one managed to get Rays extended warnings running on this latest version. Each time I try it just locks up.
ID Crying or Very sad
Works for me have you downloaded the data chck and renamed it appropiately as you are supposed to.
pips510, are you confusing the 15 voice data.chk file with the "extended version". I'm pretty sure that Ray has not yet developed the EXTENDED 30 voices!!
There is a data.chk that contains 15 spoken files on Rays site.
Steve
iPhone 6 with Western Europe & CamerAlert
keefrto
PostPosted: Wed Aug 09, 2006 9:47 pm    Post subject: Reply with quote
pip510, I did back up my 1gb version prior to the reformat, i did not include this. so alls well and the new software is aok at present.
:D
TTG300 with version 7.903. (9183/081205)OS:2344, GPS v1.21 Boot 4.8600
UK and Republic IRE MAPS v815.2024
UK and ROI with west europe major roads v675.1409
USA and Canada maps v840.2561
Captuk
PostPosted: Wed Aug 09, 2006 10:15 pm    Post subject: Reply with quote
Hi everyone, ive just updated to 6.150 installation went fine but im seem to come across one problem when i click on mobile phone icon, then call , the phonebook entry is not high lighted is there anyway to manual type into the phone book? look forward to anyone that can help me out.
My Mobile phone is a Sony E 910i.
Many thanks
pip510
PostPosted: Thu Aug 10, 2006 5:27 pm    Post subject: Reply with quote
Many thanks
Yeah connect your tom tom to the pc and open up the phonebook and add the phone numbers manually, though I would try leaving the phone to it again. I used to have this problem with mine but if you let it go for long enough it did back up to tom tom eventuially though it was by no means fast
TomTom 300
Tom Tom 500
Let's Be Safe Out There
Captuk
PostPosted: Thu Aug 10, 2006 6:19 pm    Post subject: Reply with quote
Hi there when i link the tomtom to my PC what the folder called for the Phonebook on the tomtom.
geraint
PostPosted: Thu Aug 10, 2006 11:52 pm    Post subject: Reply with quote
One of the changes TomTom have made is to move where the application thinks your contacts are.
Your contacts are in a file called contacts.txt, which used to be in the root directory, but is now in a subdirectory called contacts.
What the update seems to have done is to create the contacts directory and put an empty contacts.txt into it. This is why your application has greyed out your phonebook - it thinks it's empty.
Luckily, your original contacts.txt should still be intact in the root directory. If this is the case, simply copy it to the contacts subdirectory, and it should work again.
At least, this is what happened to me.
TomTom like to keep us on our toes...
Geraint
TomTom for iPhone v1.9
App version: 8.300 (777309)
Map: Western Europe v875.3668
keefrto
PostPosted: Fri Aug 11, 2006 9:28 am    Post subject: Reply with quote
Anyone had this problem since downloading 6.15? My screen after switching it off, appears to have a faded splash screen just noticeable still showing. The on / off liht is off, however the unit's battery this am is completely flat. Will spk to tt this am to find out.
Question 8O
rb5286
PostPosted: Sat Aug 12, 2006 8:35 am    Post subject: Reply with quote
i have just performed the latest update via TT Home and have found the following problem:
TTG goes to re-boot after disconnecting from laptop but just sits there on the splash screen.
I left it for approx 5 minutes with no change.
Am I just impatient and should wait longer or is it crashing on me?
I have tried installing the new update twice now and have had revert back to v5.44 but have lost all my favourites now!!!!
arfurdent
PostPosted: Sat Aug 12, 2006 10:43 am    Post subject: Reply with quote
join the club, TTSupport have had about six goes at fixing this. It is related to the SD card type. I am using a Kingston Elite 256MB SD card which will not work with v6.15. Use the original TT SD card or get another one
keefrto
PostPosted: Sat Aug 12, 2006 11:59 am    Post subject: Reply with quote
hi rb5286, go back a page on this forum and see if what i did helps. you should not really need to get another sd card
good luck
cptbrian
PostPosted: Sat Aug 12, 2006 4:15 pm    Post subject: Reply with quote
sixonenine wrote:
I don't know if it's just 'cos I'm stupid, but I can't figure out how to get text to speech to work on my 700. Just installed 6.15 but couldn't get it sorted on .14 - Does it actually work then? I just get a message saying because I've chosen a recorded voice (all I use is the default UK woman) that text to speech won't work. Any advice? Thakns in advance [619]
Try using Catherine uk Computer generated voice it workd on my 910
pip510
PostPosted: Sat Aug 12, 2006 4:18 pm    Post subject: Reply with quote
Text to speech will not work on any other Tom Tom model apaprt from the 910 as the programme uses 4 gb of memory
TomTom 300
Tom Tom 500
PostPosted: Sat Aug 12, 2006 5:53 pm    Post subject: Reply with quote
Not strictly true. Each voice uses about 300MB.
Having said that it would appear that you should be only using this on a 910. On anything else, it's not kosher. Probably in TomTom case - verbotten.Smile
TT Via 135 App 12.075: Europe Map v1140
PostPosted: Sat Aug 12, 2006 6:48 pm    Post subject: Reply with quote
Is this reply a day early? or do you allways use "Sunday" names, I have no Catherine computer voice on my 910, there is one called Kate though Laughing Mike
MickeyM
PostPosted: Sun Aug 13, 2006 12:09 am    Post subject: Reply with quote
Have just upgraded my Classic to 6150,was a bit slugish to begin with,as I had to tap screen quite hard to get pages up,but getting better now. Have loaded data.chk 7120 into unit and made the previous one data.chk old, but I am not getting voices (they are activated) for Gatso,etc, tried 7080 as well to no avail, can anyone help please,by the way I dragged and dropped into place, did not go through Tomtom home as did not know how with data.chk. Mike
Page 4 of 6
22.123 (18 Dec 24)
