colinra Occasional Visitor
Posted: Thu Jun 15, 2006 11:26 pm Post subject: Spain and UK Maps question |
Ok, I have recently purchaced a TT One and I am new to this Sat nav stuff.
Can I download the additional map from TT and buy a bigger SD card then copy all the files over onto one card and have working maps of Spain and the UK at the same time?? |
sgould Frequent Visitor
Posted: Fri Jun 16, 2006 12:07 am Post subject: |
Yes!!
But you will need to use the Change Prefs/Manage Maps/Switch maps to change between the two maps. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Jun 16, 2006 12:24 am Post subject: |
Remember each map download is about €60, whereas the Full European mapping is €120. So if you plan, for example, to include the French map at a later date, it would be better to get the Full European mapping. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Fri Jun 16, 2006 12:25 am Post subject: |
fantastic. :D
thanks for your help |
Posted: Fri Jun 16, 2006 12:26 am Post subject: |
Quote: | But you will need to use the Change Prefs/Manage Maps/Switch maps to change between the two maps |
Unless the Spain plus map is loaded when you can select the Spanish map before leaving the UK, set the detination and be guided over the Major Roads of Europe through GB and France and on arrival at the Spanish boarder have Street level without a switch.  _________________ Formerly known as Lost_Property
DaveO1959 Occasional Visitor
Posted: Sat Jun 17, 2006 1:07 am Post subject: |
I have the standard GB maps that came with my ONE and the France Plus maps on a seperate SD card and want to put them on one SD card as well.
Am I right to assume I copy the entire contents of the orignal SD card that came with the ONE onto the new SD card and then just the France_Plus-Map folder off the French map card?
Thanks,
Dave |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sat Jun 17, 2006 7:37 am Post subject: |
Yes. Just make sure you Copy it to the Root of the SD Card. _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Sat Jun 17, 2006 2:01 pm Post subject: |
Oldboy wrote: | Yes. Just make sure you Copy it to the Root of the SD Card. |
Great. Thanks very much.
Dave |
