Pocket GPS World :: View topic - Estimated Journey Times
mini1400
PostPosted: Thu Nov 24, 2005 3:38 pm    Post subject: Re: Old news Reply with quote
leonardo1 wrote:
I also have TTN5.1 to show the speed and most of the time it was showing 3-4 mph below the actual speed I was driving and consequently the ETA was about 10-15 mins longer than the actual journey time.
TomTom will be showing the TRUE, your speedo will show slightly faster.
leonardo1
PostPosted: Thu Nov 24, 2005 4:51 pm    Post subject: Sorry? Reply with quote
How can that be? Are you saying the speedo in my car is incorrect?
If so, how come the ETA shown on the TTN is more than 5 mins out from the time I actually got home? I remember the TTN saying I'll be home by 10:36 pm and yet I got home before 10:30.
My car is a new Mercedes C-class and the onboard computer tells me things like the time lapsed since the start of journey, no. of miles travelled so far, no. of miles left in the tank, miles per gallon, miles per hour and it's pretty accurate as far as I can tell.
Just curious.
TomTom Navigator 5.10 on Dell Axim 50v
TomTom bluetooth GPS
Sandisk 1Gb CF, TomTom 128Mb SD card
TomTom powered cradle
mini1400
PostPosted: Thu Nov 24, 2005 5:21 pm    Post subject: Re: Sorry? Reply with quote
Yep, they have to be. ALL speedos overread. If they under read imaging the problems it would cause with people getting caught with speeding!
The Manufacturers make them overread by a tiny amount to stop this problem...
leonardo1
PostPosted: Thu Nov 24, 2005 6:40 pm    Post subject: Err... Reply with quote
I can understand your case on under-reading the speedo, why don't the manufacturers make the speedo to show the EXACT speed?
I'm sure some of you will have come cross those temporary speed indicators that are placed in city centres and some rural roads that flash the speed of your car as you drive toward it, and whenever I managed to get one of those to flash the speed of my car back at me, I noticed that my speedo indicator and the digital display on the road speed indicator pretty much match each other, i.e. if I was doing 45 mph on the 40 mph road, the indicator on the road actually flashes 45. So, where's the inaccuracy? Is it only at high speeds?
Sorry, I understand this discussion is nothing to do with TTN5 but please bear with me.
Len
julianbarker
PostPosted: Thu Nov 24, 2005 11:55 pm    Post subject: Reply with quote
My guess is that the speed indicators you talk about are set low to make people slow down at black spots.
As for why car speedos are not accurate - think of the factors - a simple one - a brand new tyre has about 5mm of tread. A worn one has 2mm. That is a difference in radius of 3mm = difference in circumference of nearly 2cm. That means the potental error between a new and a worn tyre is about 1% in indicated speed. The manufacturor can't be sure how worn the tyre is, so can't build an accurate speedo.
That is just one factor - there will be wear in the gearbox, differences in tollerance in various components etc. No car speedo can be accurate as it relies on a relationship betwen the speed in the geabox and that of the road wheels. AGPSr measures actual movemeent across the surface of the Earth's spheroid. That is why GPS tends to be more accurate than any car speedo. As manufacturers can't provide an accurate speedo, the provide one that deliberatly over measures speed. That way the customer is happy becasue they think their car is faster than it is, and they get fewer tickets.
peterc10
PostPosted: Fri Nov 25, 2005 12:56 am    Post subject: Reply with quote
Another factor is that the same car model will have different size wheels depending upon the trim level. However the speedo is normally same across the range. I know that larger wheels often have "flatter" tyres but they wont be exactly the same diameter. Also the different tyre manufacturers have slightly different diameters. All adds up to mean that speedos will rarely be very accurate.
I read in one thread that GPS was accurate to plus or minus 0.1mph. There again 74% of statistics are made up on the spot.
Robin2
PostPosted: Fri Nov 25, 2005 2:29 am    Post subject: Reply with quote
It's been on this forum many times before. All new cars must have speedos which over read between 0 and 10%. To allow for manufacturing tolerances, tyre wear etc, a typical speedo will over read by 4 or 5%.
GPS speed indication is accurate to about 0.1mph, but only of you are travelling at a steady speed and on the level. I have 2 cars, and under these conditions the speedo indication at a true 70mph is 74 on one and 73 on the other.
Robin
Satmap Active 10
Qhunter
PostPosted: Sun Nov 27, 2005 1:29 pm    Post subject: Reply with quote
I've explored this issue in TT5 in some depth. I upgraded to TT5 from TT3 as a lot of other folks have and I find I can no longer take the estimated journey times seriously. I'm also bemused that TT5 doesn't use it's own planned speeds when demo'ing it's own routes.
For example: I have recently moved and for the next few months I have a lengthy, 60 mile commute on my hands. This route, apart from the first 3 miles is all on the same road, the A47 from Fenland to Leicester. According to TT5's timings the journey should take 1hr40min, a huge amount of time for what is a simple journey. To satisfy my own curiosity I let TT run the route in demo mode to see how long it would take if left to it's own devices.
Amazingly the demo took 59minutes! I do the journey, which on the whole is made up of fast, rural single carriageway, between 1hr03m and 1hr10m depending on the number of heavies I encounter. So, just what speeds it TT using for planning as it certainly aint using the speeds it does in demo mode Sad
Not being able to adjust the speeds for each type of road has been a huge failing on behalf of TT. I am seriously considering removing the entire thing and simply reverting to TT3. Very, very disappointed and I wouldn't recommend the TT3 to TT5 upgrade to anyone.
Whilst I'm having a moan, why have they changed the POI warnings from a time based warning to a distance based one? I used to have two warnings, one at 30seconds and one at 5 (to remind me I had arrived at the POI). This gave a good warning of the location of a camera at all speeds. Changing this to a distance based warning is a big backward step. 300yds for example is fine for a 30mph warning but useless for a 70mph warning.
Why haven't TT listened to its customers? As a PLC they need to listen to us now more than it did as a private co.
Qhunter
PostPosted: Sun Nov 27, 2005 2:25 pm    Post subject: Reply with quote
Border_Collie wrote:
A
How can a 300 yard warning be useless at 70 mph? The offficial stopping distance from 70mph is 105 yards, so 300 should be more than enough warning of POI's (Safety Cameras?). The distances can be changed to suit your preferences.
With the old time based warnings, the distance you were warned at varied according to your speed which in turn vary according to the type of road. A 30 second warning at 70mph gave you over half a mile to make sure you were 'in order'. With a 300 yard warning (which is fine in 30mph limits) the plod on the motorway bridge with the mobile camera has got you before you've been warned. My point is that the present system isn't as useful as the previous one.
OK, TTN5 isn't perfect but, from what I read in the forums, they are not alone in their failings.
No TT5 isn't perfect but it is a damned site worse than the previous version. Am I alone in thinking I was ripped off by TT's use of the term 'upgrade'?
Tom Symonds
PostPosted: Mon Nov 28, 2005 5:41 pm    Post subject: Reply with quote
Always worth pointing out too that ACPO guidelines for speed cameras also allow leeway to allow for inaccuracy of speed measurement.
Camera shouldn't flash you at anything less than:
SPEED LIMIT + 10% + 2mph
ie 46 in a 40 zone, 57 in a 50 etc.
neil01
PostPosted: Mon Nov 28, 2005 6:08 pm    Post subject: Reply with quote
Sorry, but you couldn't be more wrong. As a PLC, it is its shareholders it has to listen to - quite a different matter! If the shareholders say milk the cash cow and to hell with the customers, the directors have no choice other than do it, or resign.
Not nice, but unfortunately true.
Qhunter
PostPosted: Sat Dec 03, 2005 10:30 pm    Post subject: Reply with quote
I was looking at the next stage in the 'milking the cashcow' as you put it. The satnav marketplace is now flushed with affordable and functioning units. When the sales start to fall the shareholders of a PLC will want to see a change of fortune much quicker than the board of a private company would.
neil01
PostPosted: Sat Dec 03, 2005 11:31 pm    Post subject: Reply with quote
Which comes back to the problem with milking the cash cow - it often kills the cow!
But you have to remember, that shareholders who get their timings right (and some are experts in doing so) can ditch their shares at the press of a button, it is the financial gain which some are interested in.
Buy in, make a killing at any cost to the long term viability of the company, get out before the S*** hits the fan.
Don't get me wrong, I was not talking about TomTom, or any company in this sector, I simply do not know enough about them as a companies - I was merely pointing out that it is the shareholders to who every PLC is ultimately accountable.
Robin2
PostPosted: Sun Dec 04, 2005 1:12 am    Post subject: Reply with quote
The above are purely advisory, and there are a number of areas where no tolerance is allowed. Prosecutions have been made for 1mph over the limit
Robin
Satmap Active 10
DennyL
PostPosted: Thu Dec 08, 2005 12:14 pm    Post subject: Reply with quote
Coming back to the question of how Tomtom calculates journey times.
I don't see why there shouldn't be some sort of 'learning algorithm' that uses historical speed data from your previous journey and updates it as it acquires information about the speeds you are doing on your current journey. This would help to cope with the differences between speeds that we do in quiet times of the day and the speeds we do in the rush hour, and the differences between different driving styles. I can't believe it would be so complicated to implement in code. Tomtom already creates a config file, so it wouldn't be a huge step to store in it a parameter that characterizes one's speed, and once one is embarked on a journey, to extrapolate one's current speeds to estimate an ETA.
Viamichelin Mapsonic has a place to enter speeds for different classes of road, and Tomtom and Mapopolis don't. I have used Mapsonic and it was no more accurate, and one is always tempted to fiddle about with the speeds depending on the journey one was planning. My speeds very hugely depending on road conditions. I find Tomtom pretty accurate.
Page 2 of 3
