Trix Occasional Visitor
Joined: 14/06/2003 23:39:05 Posts: 5 Location: United Kingdom
Posted: Sun Sep 14, 2003 8:04 am Post subject: USB Help |
My Packard Bell XP laptop can't see the USB cable and can't find the driver
GPS is GPSmart
HELP |
Got it to work but guess that it is about 10 metres out.
Is this normal? Using a PC Map travelling along a road by the sea shows up that I am in the sea! |
Pc-Mobile Frequent Visitor
Joined: 26/10/2002 10:38:36 Posts: 789 Location: Hong Kong
It is more than likely that it is the map software that is at fault.
_________________ Pc-Mobile
http://pc-mobile.net/gps.htm |
Dave Frequent Visitor
Trix, firstly check you're using WGS84 as the datum, and secondly if you are using a scanned map, then you will need to calibrate it with more points. If you're using a commercial map product like Memory-Map, then you're probably using the wrong map datum. |
Thanks for these.
Software is Navigator GB and GPS Setting is ORD.Survey GB withBritish Grid |
Ordnance Survey GB with British Grid isn't used much, most receivers tend to prefer WGS84, so I would try setting the Fortuna to this as this might make a difference. Certainly all the Garmin's and Magellan's I set to WGS84 and these work well.
I believe there were issues with not being able to change the Fortuna's Datum, until the firmware upgrade, so you might have to download and flash it to do that. If you do, the firmware update is on our downloads page. |
Thanks for this.
My Receiver supports WGS84, and is spot on.
The firmare number on it is 1.24
Should I still try to upgrade it?
My unit is NOT Bluetooth
John |
