Pocket GPS World :: View topic - GPS Mounts
GPS Mounts
wayj
PostPosted: Sat May 21, 2005 11:27 am    Post subject: GPS Mounts Reply with quote
Hi I am new to this I would like some advice, I have an Ipaq 5550 and am thinking of purchasing a Fortuna GPS with Co Pilot live 5.
I require help with the purchase of a mount this will require a built in speaker and be able to be moved as i use a variety of pool cars at work.
Any help and advice would be appreciated
John
icsys
PostPosted: Sat May 21, 2005 12:15 pm    Post subject: Reply with quote
Hi John, welcome to the forums.
You will need a powered mount.
There are various mounting options such as the Arkon powered mount or a Seidio Ready Mount that can attach to the windscreen via a large sucker. Another suggestion is a Brodit amplified mount which are a little pricey and require a Pro-Clip specific to the vehicle so you would need a clip for each car.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
gpsmonster_uk
PostPosted: Sat May 21, 2005 5:28 pm    Post subject: Reply with quote
Hi John,
You might want to consider the Holux Powered Mount - CR100.
I have heard that the mount for the 38/39 series will fit the 5450, so it should fit the 5550 too.
This amplified powered mount also has a GPS receiver built into it and is a small compact size, minimizing cables in the car and is portable between cars.
Pocket GPS rate it 98% so it must be a good buy, see link below;
http://www.pocketgpsworld.com/holux-cr100.php
icsys
PostPosted: Sat May 21, 2005 11:44 pm    Post subject: Reply with quote
The Holux mount is a good one and one which I had overlooked, however if any of the vehicles have coated windscreen then the built-in GPS will struggle and it should be noted the CR-100 doesn't have an external antenna socket.
If you do have coated windscreen then you will need a Re-Radiating antenna that will broadcast the signal from outside the car to inside the car, but it will require an additional power supply meaning more cables.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
wayj
PostPosted: Tue May 24, 2005 4:40 pm    Post subject: GPS Mounts Reply with quote
Thanks for the advice I am looking into the sugestions
John
22.064 (26 Jun 24)
