jimbo09990 Occasional Visitor
Posted: Tue Mar 22, 2005 5:48 pm Post subject: Speed warning not working |
I have installed checkPOInt and got it working OK.
I have set up the overlays but I only hear the First and Last warnings. I never hear the warning about the speed limit.
When you assign the wav file to the speed warning tab it plays OK but just not when your on the road!
Any ideas?
James |
mossflower Occasional Visitor
Posted: Sun Apr 17, 2005 6:57 pm Post subject: |
I have the same problem and would be interested in any solution you come up with. On my Mc (a "hp 2200 with tomtom nav 3 on it ) I get an auidio warning when first entering a 30mph zone but no other speed zone is yours the same? |
Posted: Wed Apr 27, 2005 12:07 am Post subject: |
i ALSO HAVE THIS PROBLEM i HAVE INSTALLED CHECKPOINT ON 3 MACHINES SO FARFOLLOWING THE SAME PROCEEDURE EACH TIME ON THE FIRST TWO I HAD THE SAME PROBLEM IE ONLY THE 30MPH WARNING BEING ANOUNCED. ON THE LAST MACHINE HOWEVER IT WORKS ON ALL SPEED LIMITS. i AM BAFFALED. A WORK AROUND IS TO REPLACE THE FIRST WARNING WITH THE APROPRIATE SPEED LIMIT NOT IDEAL BUT IT WORKS |
CraigAH1 Occasional Visitor
Posted: Fri Apr 29, 2005 8:00 pm Post subject: |
I have the same problem. It has worked in the past but I have recently changed the overlay settings to the following
First warning 30 seconds
Final warning 20 seconds
Speed warning 10 seconds and set at the speed limit and a loud warning alert
I was hoping that this would give me 2 normal warnings and a last final load warning if I was over the speed limit (but not if I was within the speed limit.
Since doing this the speed warning has not working over or under the speed limit
Any ideas how to get this to work would be appreciated |
Posted: Fri Apr 29, 2005 8:01 pm Post subject: |
Deadly_Jowl Occasional Visitor
Joined: Jun 06, 2004 Posts: 13 Location: Sheffield, UK
Posted: Thu May 05, 2005 3:31 pm Post subject: |
I have the same problem! Is it a bug? |
Posted: Sun May 08, 2005 2:11 pm Post subject: |
i think so. I am hoping when navagator 5 coms out it will work better. Quote: | hope springs eternal |
xda Lifetime Member
Posted: Mon May 09, 2005 10:45 am Post subject: |
mossflower wrote: | i think so. I am hoping when navagator 5 coms out it will work better. |
When TT V5 comes out you won't be able to use CheckPOInt or GPSAssist as V5 won't support third party applications, that is untill TT release the code for third party apps to link in. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
xda Lifetime Member
Posted: Mon May 09, 2005 10:51 am Post subject: |
mossflower wrote: | i ALSO HAVE THIS PROBLEM i HAVE INSTALLED CHECKPOINT ON 3 MACHINES SO FARFOLLOWING THE SAME PROCEEDURE EACH TIME ON THE FIRST TWO I HAD THE SAME PROBLEM IE ONLY THE 30MPH WARNING BEING ANOUNCED. ON THE LAST MACHINE HOWEVER IT WORKS ON ALL SPEED LIMITS. |
If it worked ok on the last one you intalled it on. Was there any difference between the processor speed and available memory between this one and the first two?, _________________ Graham.
