wrinklyrocker Occasional Visitor
Joined: Oct 06, 2007 Posts: 22 Location: West Midlands & Brittany France
Posted: Mon Feb 07, 2011 1:20 pm Post subject: Downloading free POI's via POI Loader to my Garmin 255wt |
Hi first I am new to this so the problem is likely to be my doing.
I download following the steps listed and got the Zip file onto my computer OK. The POI Loader finds my Garmin device ok but says the file is empty and has no .csv or .gpx files. I have opened the zipfile and all the files have pgpsw. extentions. What can I try next?
TIA
wrinkly rocker |
Posted: Mon Feb 07, 2011 1:37 pm Post subject: |
You must unzip ("extract") the files to an empty folder and load them from there. You can't upload the zip file itself. |
Posted: Mon Feb 07, 2011 2:20 pm Post subject: ATT PaulB2005 |
Many thanks for your quick reply. I will try opening it first tomorrow.
Thanks again
w.r. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15156 Location: Bradford, West Yorkshire
Posted: Mon Feb 07, 2011 2:26 pm Post subject: Re: ATT PaulB2005 |
wrinklyrocker wrote: | Many thanks for your quick reply. I will try opening it first tomorrow.
Thanks again
w.r. |
not opening, extracting. right click the file and choose something like 'decompress' or 'extract contents'
MaFt |
Posted: Tue Feb 08, 2011 10:51 am Post subject: ATT MaFt |
Thanks for that info. I only managed to download the UK POI's after the new advice was given but trying to download the POI's for France caused the same problem ie: the file is empty or not containing csv or gpx files. maybe I neew to change the map to France before I download. I will try later.
Thanks again
wrinkly_rocker |
BigPerk Frequent Visitor
Joined: Sep 06, 2006 Posts: 1618 Location: East Hertfordshire
Posted: Tue Feb 08, 2011 11:46 am Post subject: |
You might have hit another "subtlety" with POILoader here. Make sure when you load your POIs that you load ALL of them at the same time, not just the new ones, into the same folder. POILoader does not add POIs to what you have already loaded before - it replaces everything with whatever you are just loading.
In other words, if you had loaded the PGPSW cameras, and then tried loading just your french POIs, you would lose the cameras. Remember with POILoader - "EVERYTHING, EVERYTIME" _________________ David
(Navigon 70 Live, Nuvi 360) |
Andy_P Pocket GPS Moderator
Posted: Tue Feb 08, 2011 7:29 pm Post subject: |
OR.... you may have hit an ongoing "issue" with the POIs page on this site.
At the bottom (next to the "Download" button), it says
Quote: | {tickbox} Show Link
(use 'show link' if you have problems opening the file once downloaded or if it appears to be empty) |
So you may need to download your POIs again, with that option ticked.
Once you've got the POI files themselves, follow BigPerks instructions avove to load everything ALL AT ONCE to the satnav. |
Posted: Tue Feb 08, 2011 8:28 pm Post subject: Re: ATT MaFt |
wrinklyrocker wrote: | Thanks for that info. I only managed to download the UK POI's after the new advice was given but trying to download the POI's for France caused the same problem ie: the file is empty or not containing csv or gpx files. maybe I neew to change the map to France before I download. I will try later.
Thanks again
wrinkly_rocker |
after you selected 'France' as a country, did you press the 'Refresh' button? You may be trying to download categories that we simply don't have for France.
I have updated the POI download page earlier today to try and make this a little bit clearer. The country list is now in 2 columns, the 'Refresh' button is now AFTER the country list, 'Refresh' now says 'Refresh POI List' and there is a note to say that if you change the country selection then you need to refresh the POI list.
MaFt |
Posted: Wed Feb 09, 2011 8:11 am Post subject: Problems loading free POI's |
ATT BigPerk
Thanks for you help. I am only trying to load the free POI's at the moment. I am waiting for my PayPal to clear for the Camera's which should be today. God help me with that one!
ATT MaFt
Thanks for your help. I am sure that I refresh when selecting a new country, but I will check again.
ATT Andy_P
Thanks for your help. I am using the link which enabled me to load the UK POI's, but I will try again.
Thanks for your time guys, it is appreciated
wrinkly_rocker |
Posted: Wed Feb 09, 2011 12:01 pm Post subject: Re: Problems loading free POI's |
ATT Andy_P
I do find you sometimes need to "persevere" to get those pesky POIs to download properly.
Just try all the options... Several times....On a Thursday? |
