Newsletter
Pocket GPS World :: View topic - Garmin Drive 52 - Licence Agreement
mjandar
PostPosted: Fri Jan 14, 2022 1:58 pm    Post subject: Garmin Drive 52 - Licence Agreement Reply with quote
Brand new - Every time I turn it on I have to accept the 'End User Licence Agreement' and then I have to agree to the 'Warning'.
Surely I should only need to do this once.
Am I doing something wrong?
PostPosted: Fri Jan 14, 2022 3:07 pm    Post subject: Reply with quote
The agree to the warning each start is normal. It will auto skip this if left long enough. Either tap it or just wait about 15 secs.
The user agreement can be stopped by removing the user agreement from the file system if you connect to a PC.
I can't lookup the exact file as I won't be near my PC till Sunday.
I seem to remember they are obvious but just copy them first so you can put them back if need be.
I say 'them' because there are a few in different languages, I removed all of them.
By default the user agreement is disabled on first use but I've had to manually zap it in the past.
Satnav:
PostPosted: Fri Jan 14, 2022 5:37 pm    Post subject: Reply with quote
Also you will see this initially if it has never got a satellite lock. Have you taken it outside yet so it can lock on to the satellites and get a proper fix?
PostPosted: Fri Jan 14, 2022 6:13 pm    Post subject: Reply with quote
Ooh, I never knew that! It winds my mum up everytime... Might try sort that for her, cheers
PostPosted: Sat Jan 15, 2022 4:55 am    Post subject: Reply with quote
That came from a Garmin support call many years ago when I had that issue on a previous SatNav
Satnav:
20-053 (18 May 22)
