Kremmen Pocket GPS Verifier
Posted: Thu Apr 28, 2022 10:12 am Post subject: |
I'm only guessing but look at the map options. _________________ DashCam:
Viofo A119 V3 |
Leo_A Regular Visitor
Posted: Sat May 14, 2022 8:08 pm Post subject: |
Haven't been here for a long time, however, the project continues.
Next version (just released):
- "speedo" UI improvements for splitted screen mode;
- optional "time to camera" mode : popup alert banner can display the time left to a camera in seconds (instead of meters);
- other code improvements and bug fixes. |
Posted: Sun May 15, 2022 5:05 am Post subject: |
Sounds good
As it stands it's all working OK for me, no issues. _________________ DashCam:
Viofo A119 V3 |
williamsf1 Regular Visitor
Posted: Sun May 15, 2022 9:51 pm Post subject: |
On my Samsung running Android 12 I'm getting
the screen to wake but no pop up visible ? |
Posted: Mon May 16, 2022 8:31 am Post subject: |
williamsf1 wrote: | Hi
This is the restriction of Android OS since 8.0 afair. An app can't display anything but the small notification. |
Posted: Mon May 16, 2022 11:07 am Post subject: |
Leo
Would it be feasible to put in a delay ?
The auto startup when it detects the cars bluetooth works too well
I sometimes have to kill it off to do other things on my phone before setting off. A minutes, or variable, delay before auto starting would be useful. _________________ DashCam:
Viofo A119 V3 |
Posted: Mon May 16, 2022 1:48 pm Post subject: |
Leo_A wrote: | williamsf1 wrote: | Hi
OK thanks.i 😎 |
Posted: Tue May 17, 2022 8:19 am Post subject: |
Kremmen wrote: | Leo
I sometimes have to kill it off to do other things on my phone before setting off. A minutes, or variable, delay before auto starting would be useful. |
It is possible. What is desired range of the delay? Say, 30 sec ... 5 min with step 30 sec? |
Posted: Tue May 17, 2022 8:24 am Post subject: |
I would say 0 to 180 secs in 30 sec increments as you say.
My phone Bluetooth connects to STA, Android Auto and my Garmin DS61 all from when it sees a connection.
Must get a bit confused at times as Android Auto can be anything from 10 secs to 2 mins to connect. _________________ DashCam:
Viofo A119 V3 |
ultimate Lifetime Member
Posted: Fri Jun 03, 2022 6:25 pm Post subject: |
@Leo_A
I have a couple of queries
1. Can the 'cone' for direction of travel be changed as it could on cameralert? I get some mobile cameras not alerting until right on top of then due to direction travel differential.
2. On appeoaching mobile cameras it keeps warning overspeed even if it's by only 1 or 2 miles an hour, can this be changed? I tried turning off speed excess warning but it still happens. Ideally only like it to warn overspeed if 3mph or few percent over.
Thanks |
Posted: Sat Jun 04, 2022 10:08 pm Post subject: |
I understood the problem. STA uses 'rectangle', not the 'cone'.
Width of the rectangle is 110 yds.
It is less tolerant to inaccurate camera directions, but gives less false alerts in megacities.
I'll add an option 'cone' / 'rectangle' or improve 'rectangle' detection.
App settings - Tolerance
Try to adjust 'tolerance' value. Set it +3 or +4 mph. |
brizzle16 Lifetime Member
Posted: Sat Jun 18, 2022 10:21 pm Post subject: |
Has Enforced audibility been deprecated? I have an obscure issue when paired to phone and GPS and I wanted to try changing the setting but can't find it in the app.
I'm running version 1.2.5 full version code 100 which google play thinks is the latest.
Setting referenced here in online help - https://www.speedtrap-alert.com/online-help/android/audio-settings/ |
Posted: Mon Jun 20, 2022 2:15 pm Post subject: |
brizzle16 wrote: | Has Enforced audibility been deprecated? I have an obscure issue when paired to phone and GPS and I wanted to try changing the setting but can't find it in the app.
Yes, deprecated. It stopped working on android 10. |
sijones Occasional Visitor
Posted: Mon Aug 15, 2022 9:08 am Post subject: |
Can someone offer some advice? I've always used STA successfully as a floating blue circle in the foreground of my Google Maps satnav on Android 11 (Motorola G8 Power), it's worked fine for a long time.
Now the blue circle immediately goes to '--' and doesn't show any speed or alerts. I haven't changed anything. I've rechecked the battery setting which is not optimised, the 'quick test' passes ok, 'display over other apps' is allowed. But still the blue circle is empty over Google Maps.
I've been battling this for weeks with no luck, and last night I got flashed by a speed camera whilst driving with Google Maps :-(
EDIT: I only just noticed that STA shows '--' even when it is working on its own, in the STA app. So the problem is not just when STA is overlaid over Google Maps. I never noticed this before, as I always use STA with Google Maps. If I'm going somewhere I know, I usually don't need STA either.
Can anyone help? Thanks. |
AllanKnowles Occasional Visitor
Posted: Mon Aug 15, 2022 10:15 am Post subject: |
Yes, I have the same problem when using the widget. I now start Speedtrap alert, go back to the main screen and start Copilot. That works OK. |
