Pocket GPS World :: View topic - Garmin`nuvi 52 and speed camera alerts
aidy90
PostPosted: Thu Jun 29, 2017 6:47 pm    Post subject: Garmin`nuvi 52 and speed camera alerts Reply with quote
Hi everyone
I hope someone may be able to help with my problem
when I load a route into my satnav the camera alerts work
However if I am just driving around without a route planned the camera alerts dont work
So if I just fancy a run out in the local countryside without planning a route then I have no alerts
Any help woyld be great
Thanks in advance
Aidy
PostPosted: Thu Jun 29, 2017 6:52 pm    Post subject: Reply with quote
That's a new one on me. It should produce alerts regardless.
Is this the database here or Cyclops ?
Satnav:
Car Average MPG :
aidy90
PostPosted: Thu Jun 29, 2017 6:56 pm    Post subject: Reply with quote
Its this database
PostPosted: Thu Jun 29, 2017 7:12 pm    Post subject: Reply with quote
So it was sent to the 'device' using POILoader?
The .GPI file is on it's own in the POi folder.
Might be worth running through my spoon feed post just to check it all ties up.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=97158&highlight=spoon
If that all checks out then run through the device settings.
Satnav:
Car Average MPG :
PostPosted: Thu Jun 29, 2017 7:58 pm    Post subject: Reply with quote
New one on me too, only reason you may not get an alert is if you're well below the limit.
PostPosted: Fri Jun 30, 2017 3:59 am    Post subject: Reply with quote
Oh yes, forgot about Garmin AI
Satnav:
Car Average MPG :
BAVC10
PostPosted: Fri Jun 30, 2017 6:05 pm    Post subject: Reply with quote
Do you get a visual alert if not an audible one? You should see the icon for the camera on the screen but won't get an audible alert (bong or user defined voice) if you are under the assigned speed.
DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
aidy90
PostPosted: Sat Jul 01, 2017 10:48 am    Post subject: Reply with quote
Hi all thank you for your help
I re installed everything as I normally do with POI loader and all appears ok now
thanks again
Aidy 90
PostPosted: Sat Jul 01, 2017 10:51 am    Post subject: Reply with quote
Great Very Happy
22.053 (15 May 24)
