Chinster1957 Occasional Visitor
Posted: Mon Feb 06, 2017 10:43 am Post subject: Nuvi 3598 Traffic Problem |
Hi. Not sure if anyone can help with this. I have a Nuvi3598 and it has just started to misbehave. It no longer throws up the traffic information on the right of the screen. Traffic is being registered by the unit because if I manually hit the traffic button it does display correctly, but it refuses to automatically show the traffic without manual intervention. It started happening mid journey. It was working ok, then we stopped for a rest. When we restarted our journey the traffic would not work correctly. I have tried a hard reset and that hasn't helped.
Any ideas, please? |
BAVC10 Lifetime Member
Posted: Tue Feb 07, 2017 12:16 am Post subject: |
If the traffic displays when you manually select it then the GTM traffic c adapter must be working. Normally traffic will only automatically show if there is traffic
On your route
Did you have a route selected at the time? What do your settings say for the traffic options in the menu? _________________ DriveLuxe 51 LMT D - Firmware 6.70
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3 |
Posted: Tue Feb 07, 2017 10:39 am Post subject: |
Yes a route was selected. This has happened more than once each time with a route selected.
The Traffic settings haven't changed. I have "Optimise Route" set to On Request, "Traffic Alerts" set to Most, "trafficTrends" turned off.
I also have the Traffic Map Layer ticked.
Its odd because it stopped working mid-route.
The device knew about the problems on the route because it was amending the end time correctly, it just wasn't showing it on the display unless I pressed the traffic button. |
Posted: Tue Feb 07, 2017 12:20 pm Post subject: |
Has the Traffic - compatible traffic accessory required become unticked by any chance - not sure why it would stop working en route. _________________ DriveLuxe 51 LMT D - Firmware 6.70
Posted: Tue Feb 07, 2017 2:12 pm Post subject: |
No that's still ticked. Odd isn't it. |
Dabri Lifetime Member
Posted: Tue Feb 07, 2017 5:57 pm Post subject: |
Have you possibly added another map to your unit? My 3598 suddenly decided that it would not provide traffic at all after I added a TalkyToaster map. Removing the offending map returned the traffic function. _________________ Dabri.
Navman iCN530T; Garmin 760T v4.80; Garmin 765T v4.00; Garmin 2460LMT v3.60; Samsung S3;
Garmin 3598LMT-D v5.50; Samsung J6; Garmin DriveSmart76 LT-D v6.80; Samsung A52. |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Tue Feb 07, 2017 7:06 pm Post subject: |
I have a TT map loaded and no traffic issues _________________ Where there's a will ... there's a way. |
Posted: Tue Feb 07, 2017 7:10 pm Post subject: |
I have three additional maps on my 2460 with no problem, but on the 3598 the software recognises them and throws a wobbly, viz. it either says the power lead will not charge, or it disables traffic. _________________ Dabri.
Posted: Tue Feb 07, 2017 7:36 pm Post subject: |
Ah OK, maybe a model specific issue then. _________________ Where there's a will ... there's a way. |
Posted: Tue Feb 07, 2017 10:06 pm Post subject: |
No additional maps have been added. It's all very strange. |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Wed Feb 08, 2017 9:00 am Post subject: Re: Nuvi 3598 Traffic Problem |
Chinster1957 wrote: | It started happening mid journey. It was working ok, then we stopped for a rest. When we restarted our journey the traffic would not work correctly. | My Drivesmart 50 LMTD does the same thing. If you deviate from the planned route, even slightly, when the unit recalculates the route the traffic is no longer displayed. _________________ Paul |
Posted: Wed Feb 08, 2017 10:31 am Post subject: |
Perhaps worth installing the latest firmware 5.10 as this mentions you recalculating on a route so maybe that could also affect traffic _________________ DriveLuxe 51 LMT D - Firmware 6.70
Posted: Wed Feb 08, 2017 12:21 pm Post subject: |
Currently on version 5.4. Just been on a journey. On the way there the traffic didn't bring up the right hand screen even though there was traffic on the route. Coming home, as soon as I attached the unit the traffic started working as expected. Could it be a problem with dirty pins on the magnetic holder maybe? |
M8TJT The Other Tired Old Man
Posted: Wed Feb 08, 2017 12:45 pm Post subject: |
YES. Clean them with meths or similar. |
Posted: Wed Feb 08, 2017 3:29 pm Post subject: |
Thank you. I will give that a try. |
