ROO90 Occasional Visitor
Posted: Tue Jan 26, 2016 3:15 pm Post subject: Mercedes Comand Audio Warning |
Have just downloaded the latest speed camera database and the Audio and Visual warnings on to Mercedes Comand ntg 4.5 . This latest download has seen a massive increase in the distance Audio warning, it has gone from one extreme to the other where as before the warning was minimal now the alerts go off about a 2000 mtrs. before the camera. This is causing many false alerts from other cameras not on the road being used. can the Audio distance warning bong be reduced to at least half of what it is now
Thanks |
M8TJT The Other Tired Old Man
Posted: Tue Jan 26, 2016 3:30 pm Post subject: |
The audio warning timing is nothing to do with the PGPSW data and everything to do with the device it's running on. The database is just a collection of camera locations.
Somehow, the distance warning must have been altered in your device. |
Posted: Tue Jan 26, 2016 3:54 pm Post subject: |
Okay Thanks for prompt reply. will check it out |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15142 Location: Bradford, West Yorkshire
Posted: Wed Jan 27, 2016 12:55 pm Post subject: Re: Mercedes Comand Audio Warning |
ROO90 wrote: | Have just downloaded the latest speed camera database and the Audio and Visual warnings on to Mercedes Comand ntg 4.5 . This latest download has seen a massive increase in the distance Audio warning, it has gone from one extreme to the other where as before the warning was minimal now the alerts go off about a 2000 mtrs. before the camera. This is causing many false alerts from other cameras not on the road being used. can the Audio distance warning bong be reduced to at least half of what it is now
Thanks |
We've actually tweaked the Merc files based on recent feedback. It should now give a 40 second warning - so even for a 70mph camera the maximum would be 1200is meters.
MaFt |
Posted: Wed Jan 27, 2016 4:29 pm Post subject: |
It seems like what I said above is a load of blx then? |
Posted: Wed Jan 27, 2016 4:57 pm Post subject: |
Have tried to download the latest 14.014 27 Jan 16 speed cameras today. click on same format latest downloads Keep getting Error HTP 404, have tried three different computers , three different browsers with no success
Problem has now been rectified |
Posted: Thu Jan 28, 2016 6:06 pm Post subject: Re: Mercedes Comand Audio Warning |
MaFt wrote: | ROO90 wrote: | Have just downloaded the latest speed camera database and the Audio and Visual warnings on to Mercedes Comand ntg 4.5 . This latest download has seen a massive increase in the distance Audio warning, it has gone from one extreme to the other where as before the warning was minimal now the alerts go off about a 2000 mtrs. before the camera. This is causing many false alerts from other cameras not on the road being used. can the Audio distance warning bong be reduced to at least half of what it is now
Thanks |
MaFt |
Have downloaded the latest database with the 40 sec Audible warning , checked today on a journey of 200 miles, the 40 sec warning is too long and gives massive misleading warnings , it got to the stage I pulled the sad card out. Before I commenced my return journey I loaded the sd again, same results massive irregular warnings , hopefully this will be rectified soon |
locksmith Lifetime Member
Posted: Fri Jan 29, 2016 3:19 pm Post subject: |
How many seconds warning would you recommend?
MaFt |
Posted: Fri Jan 29, 2016 3:33 pm Post subject: |
I went for 10 seconds. They are usually just in sight when the bong sounds which is fine for me. |
Posted: Fri Jan 29, 2016 4:40 pm Post subject: |
IMHO I would say 10 secs is too short |
Posted: Fri Jan 29, 2016 5:12 pm Post subject: |
locksmith wrote: | You can use MB POI loader to alter the files, |
Posted: Sat Jan 30, 2016 3:57 pm Post subject: |
Have not been able to reduce the Audible sound warning from the 40 secs set at the last updated download, as previously stated this is far too long giving many false BONGS !! , hopefully to be soon rectified |
Posted: Sun Jan 31, 2016 12:30 pm Post subject: |
I've now changed the warnings to 20 secs. If you redownload now then this will be active.
Feedback appreciated from all!!!
If you wanted to adjust the warning distance manually then open up the file in a text editor (such as Notepad on Windows [for info I prefer the free Notepad++ on Windows and TextWrangler on Mac]) and do a search/replace on the following text:
Code: | <gpxd:Activity Active="true" Level="warning" Unit="second" Value="20"></gpxd:Activity> |
and replace the value of '20' to however many seconds warning you prefer.
MaFt |
Posted: Mon Feb 01, 2016 12:45 pm Post subject: |
Have this morning downloaded the latest speed camera database with the 20 second Audible warning, This is a massive improvement, done a 40 mile trip , for me this setting is spot on , only one false Bong that was on a road running parallel to journey road with camera visible across open land . I think 10second warning would be too short a distance certainly for mobile camera positions . |
