K13ehr Lifetime Member
Posted: Thu Jan 02, 2014 11:22 am Post subject: Copilot version 9.5.0.440 importing OV2 files |
I've just got the Copilot free app to try out as Sygic just wasn't doing it for me, on the POI front, shame as it looked good otherwise.
But I don't seem to be able to make a new POI category, or even a new POI, I'd also like to import my many OV2 files.
Any help most appreciated
Kev. |
AliOnHols Pocket GPS Verifier
purplefadetogrey Occasional Visitor
Posted: Fri Jan 10, 2014 11:31 pm Post subject: Copilot 9 |
Hi, I have tried the instructions above and found that it does not work with copilot 9. It may work with copilot 8 but I cannot test. Regards Martin. |
Posted: Fri Jan 10, 2014 11:37 pm Post subject: |
Thanks for that feedback purplefadetogrey.
I have managed to put the PgpsW cameras in CSV format into CoPilot. I wonder if converting the OV2 files to CSV and importing similarly would work? _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
Posted: Sat Jan 11, 2014 11:27 am Post subject: Csv |
Quote: | I have managed to put the PgpsW cameras in CSV format into CoPilot. I wonder if converting the OV2 files to CSV and importing similarly would work?
Hi, please can you let me know how you got the CSV files to work. Did you use the 'Copilot Central' program or did you drag and drop into the 'save' folder?
Thanks Martin. |
Posted: Sat Jan 11, 2014 1:36 pm Post subject: |
I just followed the instructions on the download page which is the drag and drop method-
http://www.pocketgpsworld.com/uksafetycameras-copilot8.php
I am still finding my way around CoPilot so not really sure of what I'm doing apart from blindly following instructions, some are working, others are not.
Early days.
Good luck. _________________ Garmin Nuvi 2599
Posted: Sat Jan 11, 2014 4:16 pm Post subject: At last! |
Hi, I have worked it out at last.
It works using ov2 files not CSV.
all working okay now.
just need add one category at a time, open co-pilot and it adds them to your poi. |
Posted: Sat Jan 11, 2014 4:45 pm Post subject: Working now |
I forgot to say I am using copilot 9 |
Posted: Sat Jan 11, 2014 9:50 pm Post subject: |
Ok, after a day of experimenting, this is what I have found -
Using Android 4.0.4. and CoPilot 9.5.0.440 (downloaded recently).
I used various POI's downloaded from this site. I have read somewhere on CoPilot's help pages that the POI's need to be imported from a Certified Download Source. I'm not sure what the difference is, if anything, between this and your own POI's, but I don't have any of my own POI's immediately to hand to be able to test this.
As purplefadetogrey mentioned above, I had best success with OV2 files despite my previous upload of SpeedCameras POI's being in CoPilot 8 csv format and working well.
OK -
1) Make sure CoPilot is not running and connect Android to your PC as "Media Device". I had "debugging mode" selected in case this makes any difference.
2) Copy both OV2 and bmp files (I only copied two files at a time).
3) Paste both files into the /InternalStorage/CoPliot/??/save folder. (where ?? is the maps you have, EU in my case). Disconnect Android from the PC.
4) Launch the CoPilot app. CoPilot shall announce "New Poi set found" (and lists the poi name). Click on the Right arrow at the TOP of the screen.
5) You now have two choices - a) Import to an existing Poi category, or, AT THE BOTTOM OF THE SCREEN, b) Create your own Poi Category. You may have to hide the keyboard to see this option.
6a) Select an existing Poi category. Click right arrow.
7a) Select a Type. Click right arrow.
8a) "set options", "Are you importing Safety Camera Data?", Click Yes/No.
9a) Click right Arrow. CoPilot starts "processing" and then starts normally.
6b) To Make your own Poi category. Select "New Category" at the bottom of the screen. Enter a new Category Name. Click right arrow.
7b) Select an image to associate with your new category (see Note 1 below). Click right arrow.
8b) Select Yes/No at the question "Are you importing Safety Camera data?." Right Click.
9b) CoPilot starts "processing" and then starts normally.
10) Repeat as necessary for more Poi categories.
NOTES, 1) I noticed that recently uploaded images do not show for the first few reboots of CoPilot. Although I haven't tested it, it may be an idea to upload just the bmp files first and then the OV2 file following a reboot. Hopefully by then the bmp files shall be in the system and be presented for selection.
2) Png files appear to work just as well as Bmp files. 22x22 Pix.
3) I wasn't able to find a way of creating a POI Sub Category. If anybody finds out how to do this, please would you report back. _________________ Garmin Nuvi 2599
Posted: Sat Jan 11, 2014 10:09 pm Post subject: |
Also, Using ItnConverter it is possible to import your own itineraries.
I converted both .itn and .gpx files into .trp and imported into the same "save" folder as above. The route is then available for selection in CoPilot.
Apologies if this has all been mentioned before in these forums. _________________ Garmin Nuvi 2599
vidman Occasional Visitor
Posted: Sat Feb 08, 2014 12:54 pm Post subject: |
Just used this to load the PGPS DB as above and found that I could bulk copy the OV2 BMP files in one go and when restarting CoPilot it just automatically added all the files a Speed Camera POIs.
They all appear to work except the Average Speed Camera ones which do not give the display expected - I have started another thread for that rather than try and resurrect this one |
Fox66 Occasional Visitor
Posted: Thu Mar 20, 2014 5:21 pm Post subject: Deleting ALK speed cameras |
Having just started using CoPilot again (9.5.0.440), I have installed PGPSW speed cameras vis the CSV files - this seems to have worked fine.
I followed the instructions for deleting the ALK ones, amd they are still there!
I cannot seem to find where else they may be stored according to any instructions I have found.
V9 seems to have some changes over V8
Any ideas please?
Cheers |
MrC-299 Occasional Visitor
Posted: Sun Apr 06, 2014 7:10 pm Post subject: camera database into copilot 9 |
I've found the same, I upgraded toV9 after V8 stopped working. Alk marketing ploy?
Since then camera DB for V8 loads in but does not give the option of importing safety cameras.
I still get warnings of speed limits but no images are shown on the map which is frustrating.
A move back to Tom Tom maybe in the offing. |
M8TJT The Other Tired Old Man
Posted: Sun Apr 06, 2014 7:35 pm Post subject: Re: camera database into copilot 9 |
MrC-299 wrote: | A move back to Tom Tom maybe in the offing. | Watch out. You can't add user POIs in most of the latest TomToms  |
