Pocket GPS World :: View topic - Noza Tec Truck Low Bridges
Post new topic   Reply to topic    Pocket GPS World Forum Index -> HGV / Motorhome Lounge
Land-Rover-Driver
PostPosted: Sat Nov 21, 2015 8:30 am    Post subject: Noza Tec Truck Low Bridges Reply with quote
My Noza Tec Truck is not avoiding low Bridges I have set in the truck weight and dimensions can anyone help?
PostPosted: Sat Nov 21, 2015 9:11 am    Post subject: Reply with quote
I have read, and have tested, that, on iGO8, even though you have set the device to Imperial measurements, the input of vehicle dimension remains in metric, so try inputting the height/length of your truck by a factor of three and try again on a sim route. Metric tonnes and Imperial Tons are pretty much the same, but I can't remember if the weight is in tons/tonnes or lbs/kilos. This may or may not be true of later versions of iGO software. Please let me know if this works or not.
Land-Rover-Driver
PostPosted: Sun Nov 22, 2015 7:51 am    Post subject: Reply with quote
Hi M8TJT
I have tried what you suggested but unfortunately on luck I still keep hitting bridges!
PostPosted: Sun Nov 22, 2015 9:54 am    Post subject: Reply with quote
Then I give in? Ask me one on F1 Very Happy Sorry I couldn't help' I did try it on my iGO8 Truck version and it worked. If a bridge was 12ft high, I had to set my vehicle height to at least 36ft.
BTW, there is a 'Post Reply' button at the bottom left of the page. There is no point in 'Quote'ing the message immediately above, it just clutters up the page with unnecessary repeats of stuff.
Land-Rover-Driver
PostPosted: Sun Nov 22, 2015 4:12 pm    Post subject: Reply with quote
Thanks for all your help
PostPosted: Sun Nov 22, 2015 4:17 pm    Post subject: Reply with quote
No problem. Any more questions? Just ask.
Land-Rover-Driver
PostPosted: Tue Nov 24, 2015 10:15 pm    Post subject: Reply with quote
I have found out why I'm hitting bridges (I hope)
My sat nav is missing the United_Kingdom_2014.Q4_150302.ftr map file
Can any one help?
PostPosted: Wed Nov 25, 2015 1:23 am    Post subject: Reply with quote
That'll do the trick. Do you not have an older one? It should still work.
Land-Rover-Driver
PostPosted: Wed Nov 25, 2015 6:15 am    Post subject: Reply with quote
No unfortunately it was missing from new
Dose anyone out there have a "Noza Tec Truck" Sat Nav if so can you email me this map file:
GJH
PostPosted: Wed Nov 25, 2015 8:04 am    Post subject: Reply with quote
As far as I know the file United_Kingdom_2014.Q4_150302.ftr does not exist in the download sets offered by Noza Tec and similar Chinese brands. I'm surprised that they aren't supplying an alternative .ftr file with new units though as that is bound to cause problems.
I am using the United_Kingdom_83_HERE_2014.Q3_141213_(TI).ftr file with the 150302 set and, as M8TJT says, it works fine.
If you send me your e-mail address in a PM I'll be happy to send it to you as an attachment.
Graham
PostPosted: Wed Nov 25, 2015 11:20 am    Post subject: Reply with quote
GJH and L-R-D. You both have PMs.
Mark_trucker
PostPosted: Sun Mar 13, 2016 12:14 pm    Post subject: ftr file Reply with quote
Hi everyone!
I have no .FTR file for UK maps
PostPosted: Sun Mar 13, 2016 5:26 pm    Post subject: Reply with quote
Without a .ftr file, it won't works. Even then you need the right combination of .ftr and map file. Get on to Nozatec and see if they come up with something as it was sold as a truck device.
What version if iGO do you have on your device Menu~Help~About or somesuch it will be like 9.6.209584. I have that version with some 2013 maps that do work in Truck mode, but it seems that you need a .ftr that matches the map file version. The NQ maps also have the driver alerts in them that the TT maps don't.
GJH
PostPosted: Mon Mar 14, 2016 8:03 am    Post subject: Reply with quote
It would appear from other forums that the problem of missing .ftr files, and unsuitable files generally, is not confined to Nozatec but affects other brands as well.
Looks like NNG/Naviextras may well have found a way of preventing map sets from being cracked/copied for the time being.
PostPosted: Mon Mar 14, 2016 10:18 am    Post subject: Reply with quote
There still seems little excuse for not including the FTR file in their map set (even if it doesn't work)
Post new topic   Reply to topic    Pocket GPS World Forum Index -> HGV / Motorhome Lounge All times are GMT + 1 Hour
20.121 (07 Dec 22)
Terms & Privacy
