Newsletter
Pocket GPS World :: View topic - Ash10's Voice Utility Software
Goto page 1, 2, 3 ... 13, 14, 15  Next
Ash10
PostPosted: Wed Feb 07, 2007 2:19 pm    Post subject: Ash10's Voice Utility Software Reply with quote
I've been busy writing some more new software - it's rather unimaginatively called Voice Utility, and here it is Cool
http://tinyurl.com/238t6o
Voice Utility will take any Garmin VPM file (not just British_English Smile ) and split it into its component audio samples. Once you have changed the samples as you see fit, Voice Utility will then join them back up into a new VPM file for you.
The free version of Voice Utility allows you to change as many (or as few) of the samples as you wish - however, after you have changed fifty samples, the quality of subsequently changed samples will be reduced slightly (although this will not stop your voice file from working).
You can remove this limitation by making a small Paypal donation - there is no minimum amount as such, but as a rule of thumb I like to have enough left after Paypal's cut for a beer or two... Wink
There's no need to have the samples in any particular format - Voice Utility will convert 16-bit (linear PCM) or 8-bit (u-law or a-law) samples, mono or stereo, of any sample rate, into the correct format automatically.
This free version is for personal use only - commercial use prohibited without permission
How to get at your VPM files:
On an i3, the VPM files can be found on the memory card - in the /Garmin/Voice/ directory. You'll need a suitable card reader to be able to get at them - if your i3 doesn't have a memory card, then I'm afraid that it can't be done.
On a Nuvi, connect the unit to your computer and you should find the VPM files in the /Garmin/Voice/ directory.
Take a backup of your VPM file before doing anything else!
To split a VPM file into its component samples, run Voice Utility and point it to the file that you want to split. Choose a name for the extracted samples in the space below, then click on the Split button - the numbered samples will be extracted and saved to the specified directory.
To join component samples into a VPM file, point Voice Utility to the first sample (only the first sample in each series is displayed in the file dialog). Choose a name for the new VPM file in the space above, then click on the Join button - it's that simple.
Once you've modified a VPM file, you'll need to set your unit to a different language and then back again to force it to update itself.
Note that the first sample (numbered as _000) is special and should not be altered!
Enjoy! Cool
Beerbellybill999
PostPosted: Wed Feb 07, 2007 2:34 pm    Post subject: Reply with quote
Thanks Ash, What would we do without you!
How do you find the time?
I will test it tonight
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
Ash10
PostPosted: Wed Feb 07, 2007 2:38 pm    Post subject: Reply with quote
Out-of-work at the moment... Crying or Very sad
missing_user
PostPosted: Wed Feb 07, 2007 3:17 pm    Post subject: Reply with quote
Hi Beerbellybill999!
Have not seen you posting for a while!
Happy new Year.
hodgy
PostPosted: Wed Feb 07, 2007 7:46 pm    Post subject: Reply with quote
Cheers Ash10!
Works perfectly for me [Garmin C510]
Just need to create that blank wav then away you go, thanks!
Matt
PostPosted: Wed Feb 07, 2007 10:01 pm    Post subject: Reply with quote
so then, are people gonna start posting vpm files any time soon then? i can't be bothered doing my own ;)
Ash10 - you're a star! you'll get some work soon (he says hopefully)
Brian
PostPosted: Wed Feb 07, 2007 10:47 pm    Post subject: Voice Utility Reply with quote
Tried it on English_American_.vpm and English_British_.vpm .. works great, tried it on English_British_Emily.vpm but did not work. Am I right in thinking it is not compatable with the TTS files?
Aprilia Tuono, Zumo 550
Ipaq 2210/Fortuna/TomTom Nav6
& Road Angel 7000 + Memory Map
Abakus
PostPosted: Thu Feb 08, 2007 9:14 am    Post subject: Re: Voice Utility Reply with quote
TTS is a totally differernt story, much more much smale voice splits.
Mate
PostPosted: Thu Feb 08, 2007 10:44 am    Post subject: Re: Voice Utility Reply with quote
Ash10, great work man !!
Just one question. wil this create a new voice name in the menu or does it overwrite the original voice file.
I understand the naming of the voice file is embeded in the file. Would it be possible to alter this name so you can select it on the device?
But could it be done?
locksmith
PostPosted: Thu Feb 08, 2007 11:00 am    Post subject: Reply with quote
Being a thickie, what on earth is this ? Embarassed
Ash10
PostPosted: Thu Feb 08, 2007 11:19 am    Post subject: Re: Voice Utility Reply with quote
You need to replace the original VPM file with your modified one (remember to backup the originals first!) - so no, it won't add any menu entries.
I have mine set up like this:
- English_British - "recalculating" replaced with silence, and the camera approach and overspeed bings and bongs made louder.
- American_English - all speech replaced with silence, so just the assorted bings and bongs.
This is great for when you roughly know where you're going, and the constant voice directions are annoying - whenever you're not quite sure of the route, a quick glance at the screen shows the way.
currymonster
PostPosted: Mon Feb 19, 2007 4:05 pm    Post subject: Reply with quote
If anyone simply wants to silence the annoying 'recalculating' then the doctored British voice file can be downloaded from here:- http://tinyurl.com/2z4fgh
Be sure to back up your old voice file first. I make no guarantees, but it does work for me on a Streetpilot i3.
Jamas
PostPosted: Tue Feb 20, 2007 11:36 am    Post subject: Re: Ash10's Voice Utility Software NEW! Reply with quote
Ash10 wrote:
I've been busy writing some more new software - it's rather unimaginatively called Voice Utility, and here it is 8) http://tinyurl.com/238t6o
Idea Thanks a lot Ash10 for the frenchies Wink . Will try tonight
Jamas
SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+
snowboardcriminal
PostPosted: Tue Feb 20, 2007 2:13 pm    Post subject: Reply with quote
Hi all and thanks for the great work Ash.
Simple question, can you just not rename the vpm file so that you get another choice? so you have the orignal English version then have the option of using a doctored version called somthing else, rather than "over writing an existing set of files?
I am probably missing somthing really simple, but i am just a simple folk!
Don't eat yellow snow
i3, on the middle of the dash, works just fine!
There are things that I know and you don't know, there are things that you know that i don't know, but always remember there is much that we both don't know.
PostPosted: Wed Feb 21, 2007 11:25 am    Post subject: Reply with quote
Ash, a quick question to clear something up before people start sharing files:
will a vpm file from, say, an i3, work on a nuvi or a c320 etc?
I can just imagine people editing their i3 files and uploading them for all to use and end up killing a different unit...
or do you want me to try it out between my i3 and nuvi?!
Page 1 of 15
20.054 (25 May 22)
