Pocket GPS World :: View topic - Installing speed camera POIs on a VW Passat
walberton
PostPosted: Tue Nov 12, 2019 5:23 pm    Post subject: Installing speed camera POIs on a VW Passat Reply with quote
I have a 2017 VW Passat which is fitted with Discovery Media (Generation 2). Data is supplied and updated via an SD card. I have been trying to download the speed camera file and then add this to the POIs that already exist in the inbuilt GPS system. Can anyone tell me which SatNav system I select on the drop down menu and what file format I need in order for the built in equipment to read the data from the SD card? Many thanks in anticipation. Martin
PostPosted: Tue Nov 12, 2019 5:40 pm    Post subject: Reply with quote
Does this VW system allow POI's with proximity warnings ?
Most inbuilt systems only support POI's as navigation points.
Allan_whoops
PostPosted: Tue Nov 12, 2019 6:08 pm    Post subject: Reply with quote
There are issues but you may find this article helpful despite being a Seat site - same bits. It tells you how to install the cameras from here onto VAG satnavs
https://forums.seatcupra.net/index.php?threads/uploading-speed-camera-pois-tail-of-woe-vw-pulled-the-update-site-again.444799/
walberton
PostPosted: Tue Nov 12, 2019 6:45 pm    Post subject: Reply with quote
Many thanks for the suggestion. I will explore the options you have put forward.
Tom59
PostPosted: Fri Nov 22, 2019 1:50 pm    Post subject: Reply with quote
I used the "Garmin POILoader [UK - Consolidated By Type (Gatso,Mobile,etc) | pMobiles: Yes | French: No | Swiss: No ]"
The cameras are downloaded OK, but you cannot get sound warnings.
TT Go 720 (T)
Firmware 9.430. Map: Western Europe V 875.3613
TT iPhone app
V 1.23 Map: Western and Central Europe 2 GB V 965.7286
TT iOS Go Mobile
V 1.1 Map: Western Europe 965.7248
walberton
PostPosted: Fri Nov 22, 2019 7:06 pm    Post subject: Reply with quote
Thanks. I will look for that and give it a try
