Pocket GPS World :: View topic - POI Download limit and saving list
K13ehr
PostPosted: Fri May 02, 2014 9:24 am    Post subject: POI Download limit and saving list Reply with quote
Does the 20 sub cat limit mean I can load say 20 supermarkets, bit that's all, then I need to download again anything else (sorry in thick mode today) is there a limit for repeated downloads.
Also is there a way to save the categories of of my favourite POI downloads so I don't have to re-select them each time, maybe even the option to save different groups and be able to edit them as I need different POI depending on where I'm heading, IE in the UK or another country.
Kev
Daggers
PostPosted: Fri May 02, 2014 10:54 am    Post subject: Reply with quote
The 20 sub-category limit only applies if you select the option to "Combine subcategories into category file" (i.e, rather than seeing separate POIs for Asda, Morrisons, etc, you just want a single POI file called supermarkets.
I believe the limit only applies when you have 20 in a single category, not when you have 20 or more across different categories. There's only one way to find out!
Unfortunately, there is no way to save the categories for future downloads - the list on the screen is built on the fly, so in theory it could be completely different next time you download it (obviously this won't happen in practice, but it does make things awkward for trying to memorise results).
Garmin DriveSmart 50 LMT-D
