tonyboundy Occasional Visitor
Posted: Fri Jul 05, 2013 1:13 pm Post subject: i cant get speed cameras onto my Kenwood DNX520VBT |
I follow all the instructions but when i insert the SD card nothing happens. I go into "my data" and all it says is to download new data from WWW.Garmin etc. help please. |
sgould Frequent Visitor
Posted: Fri Jul 05, 2013 11:39 pm Post subject: |
I don't know your particular device, but there have been some recent comments by Kenwood users on the web that the method for installing POIs can vary from model to model.
Does your model have a USB connection? It may work from that. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Mon Jul 08, 2013 6:43 pm Post subject: |
sgould wrote: | I don't know your particular device, but there have been some recent comments by Kenwood users on the web that the method for installing POIs can vary from model to model.
Does your model have a USB connection? It may work from that. |
Hi, its the Kenwood one especially made for the VW group (Golf, Eos etc) and to load updates you have to download from PocketGPSworld onto a SD card using the POI loader program from Kenwood then put it in the machine and load it? but thats the problem as it doesnt seem to recognise the card or data on it? it just says go to kenwood for updates?? Thanks |
chrisjs007 Occasional Visitor
Posted: Fri Oct 11, 2013 11:38 am Post subject: |
I don't know if I'm too late with this, but had the sane problem with the SD card and ended up using the USB connection which then worked |
mekanik Occasional Visitor
Posted: Tue Oct 29, 2013 1:40 pm Post subject: I cant get speed cameras onto my DNX520VBT |
I don't know if I am too late to respond to this also, but I have had the same problem with the DNX520VBT too.
However, after experimenting, and using the usb at the rear, I think I have discovered the way to do it, I say think because I'm not sure whether I'm seeing the new updated files, or the ones I originally uploaded via usb, some way of checking the date of the files on the unit would be nice.
the method I used is as follows :-
Insert Micro SD card
On the nav screen tap 'Where to'
scroll down to 'Extras'
select 'Custom POIs'
Select 'All Categories'
you should then see an egg timer, which I assume the device is reading the card/unit memory.
a list should then appear showing the different camera categories.
Like I said I'm not sure if it's showing the new ones or not, but if you have never uploaded any files before to the unit, you could use this method to verify if it does or doesn't work. |
M8TJT The Other Tired Old Man
Posted: Tue Oct 29, 2013 3:27 pm Post subject: Re: I cant get speed cameras onto my DNX520VBT |
mekanik wrote: | I say think because I'm not sure whether I'm seeing the new updated files, or the ones I originally uploaded via usb, some way of checking the date of the files on the unit would be nice. | A little 'outside the box' but how about creating an almost blank database and then load that. If you still have loads of cams, it is not being loaded. Don't forget to reload the full database afterwards though. |
