Pocket GPS World :: View topic - A work around for navigate to postcode problem with Go's
alan195
PostPosted: Tue Sep 10, 2013 6:26 pm    Post subject: A work around for navigate to postcode problem with Go's Reply with quote
There is a problem with the new Go 400/500/600/6000s when navigating to a UK postcode without a house number. At the moment, after selecting the street and then “Drive To” it takes you to the start of the road rather than the postcode. In the case of some roads you may be miles away from where you want to be. I have come up with a work around for this problem.
Search for the postcode and, after selecting the road, instead of choosing the “Drive To” option pick the “Show On Map” option. This will show you the middle of the postcode. Press on the screen near the postcode & it will come up with an option to drive there. Select this option & it should navigate you to the postcode rather than the start of the street.
This is not perfect but at least it should help until TomTom sort it out
Alan
Go 740 Live
Go 600
PostPosted: Tue Sep 10, 2013 10:59 pm    Post subject: Reply with quote
Thanks for the tip!
"Settling in nicely" ;-)
