Pocket GPS World :: View topic - Internal Memory Nearly Full
keithmillar
PostPosted: Sat Aug 31, 2013 11:13 pm    Post subject: Internal Memory Nearly Full Reply with quote
I've noticed that my 7gb memory on my 3598LTM-D is nearly full - I have 91mb of space left.
Is there a way I can strip the device of items that I don't need or have use for - and would it be a case of just simply right click and delete.
There is a 4gb memory card in the unit as well but at present i'd rather keep everything in just the same place.
Keith
Keith
Garmin 3598LTM-D
Android CoPilot
Navigon 72 Plus Live
TTGO540
PostPosted: Sun Sep 01, 2013 7:28 am    Post subject: Reply with quote
See here for tips on How to make more space for a map update
Much of it applies to your model, although you may need to set it to mass storage mode to access all the files. To do that:
1. Start NUVI by itself and go to Volume Screen.
2. Press the upper right hand corner of screen for 10 seconds.
3. The Developers Screen will pop up
4. Scroll down to MTP SETTINGS
5. Change from AUTO DETECT to MASS STORAGE
6. Shut down NUVI and connect to PC
7. It should now connect in mass storage mode.
As an alternative to step 1 above, you can bring up the Nuvi's "dashboard" screen, then press and hold the speedometer for about 10 seconds to access the developer screen.
22.053 (15 May 24)
