Pocket GPS World :: View topic - Warning over Bluetooth fails after some time
CAA_0821145133
PostPosted: Sat Dec 29, 2012 9:36 pm    Post subject: Warning over Bluetooth fails after some time Reply with quote
Phone: Nexus 4, stock JB 4.2.1
Car: 2011 C Class with Command Online.
No problem connecting to car Bluetooth. Handles calls with no issues.
Setup CamerAlert to deliver warning over Bluetooth. (device linked to account)
Initially everything work as it is supposed to. App is running in foreground
Then
CameraAlert stops sending the warnings over bluetooth after some time (about 10 minutes). Warnings are still shown on the phone screen, but no sound (via bluetooth). Phone remains connected to bluetooth as can still make and receive calls,
Can anyone help? Is this a bug in the app?
PostPosted: Sun Dec 30, 2012 3:03 am    Post subject: Reply with quote
So you specifically selected Bluetooth Headset in the CamerAlert sound settings? Do you know if your car also supports A2DP (Stereo audio)? If yes, then you may be able to use the default audio routing setting instead, and maybe let us know if that behaves differently?
PostPosted: Sun Dec 30, 2012 9:15 am    Post subject: Reply with quote
Lutz this happens on iOS too. Phone call stops BT audio. Close and restart CA restores audio. I thought we had long ago reported this and it was in the pipeline for fix.
CAA_0821145133
PostPosted: Wed Jan 02, 2013 4:36 am    Post subject: Reply with quote
OK looks like this may be the solution.
The car does support A2DP
What I have done is under Bluetooth settings,
The options for the car Bluetooth (MB Bluetooth) was for Phone Audio and Media Audio. Both were selected.
I have unchecked Media Audio (as I don't stream from my phone anyway)
will report back.
On a different note completely, it seems Google is crippling Android more and more with each update, e.g. now Airplane mode is now secure, so you cannot get Profile Apps like Llama to get the phone into Airplane mode at set times ... grrrr
CAA_0821145133
PostPosted: Wed Jan 02, 2013 5:34 pm    Post subject: Nopes Reply with quote
Update
Above this does not fix this.
Also cannot get Google navigation to output guidance over bluetooth
Any ideas?
CAA_0821145133
PostPosted: Fri Jan 04, 2013 3:24 am    Post subject: Reply with quote
More tweaking, but still not quite acceptable.
If I have Google navigation (which seems to only work via phone speaker)
ALSO running in the background
AND keep the screen ON
(I don't usually have a lock screen set up anyway, when I switch on the screen I go straight to the homescreen)
then and only then it seems, the warnings goes and continues over bluetooth
CAA_0821145133
PostPosted: Sat Jan 05, 2013 6:33 pm    Post subject: Multitasking failure Reply with quote
Given up on Bluetooth issue.
But now, it seems, the app just stops working in the background.
7 hr drive yesterday, initially working (via phone speaker). once screen goes off, it seems to stop working. Switching the screen ON seems to starts the GPS listener again.
PostPosted: Mon Jan 07, 2013 9:55 pm    Post subject: Reply with quote
sorry to hear about your issues. The app normally only terminates after 10 minutes of no GPS changes. In your trip did you maybe have breaks where you were stationary for more than 10 minutes?
CAA_0821145133
PostPosted: Tue Jan 08, 2013 4:43 pm    Post subject: Reply with quote
Stationary : YES, but the app stopped sending warnings long before that
(at least 1 hr before I stopped)
Once I resumed my journey, the app started working again after a few of hours (despite screen being off)
So not quite sure what's going on there ...
PostPosted: Tue Jan 08, 2013 8:43 pm    Post subject: Reply with quote
Not sure what to suggest (apart from the non-productive "get another car").
Is it feasible to use the phone speaker instead of Bluetooth?
CAA_0821145133
PostPosted: Wed Jan 09, 2013 12:59 am    Post subject: Reply with quote
I have given up on the bluetooth.
But the main issue at the moment is that CamerAlert does not seem to work reliably in the background (stops working after 15-30 minutes)
22.051 (01 May 24)
