Pocket GPS World :: View topic - 2595 closing down when using voice command
HOOPEY
PostPosted: Tue Nov 13, 2012 11:52 pm    Post subject: 2595 closing down when using voice command Reply with quote
I have recently bought a Garmin 2595 LMT. All was well until i tried to use the voice command " find place". When i told it to search for a place it causes the unit to shut down! It is only that one command that has this effect,
I phoned the Garmin boys and they said their version was working ok therefore it must a fault with the unit (not a software glitch!!!)
Therefore off i go back to Halfords who as good as gold replace the unit having confirmed by testing it thenselves that it did switch itself off.
All goes well over several days. Then i decide to check for map and software updates which i downloaded. Hey presto the voice command problem rears it's ugly head again.
Has anybody else encountered this problem or do i go back to Halfords once again!!
Huw
PostPosted: Wed Nov 14, 2012 8:15 am    Post subject: Reply with quote
If you've downloaded new maps and software you ought to do a hard reset first, that often cures 'glitches' after updates.
