Pocket GPS World :: View topic - Kenwood DNX7280 will not 'Replace' existing poi.gpi file
CA_0610130749
PostPosted: Sun Jul 22, 2012 1:39 pm    Post subject: Kenwood DNX7280 will not 'Replace' existing poi.gpi file Reply with quote
Having previously loaded poi.gpi file to the unit I am finding it impossible to update/replace the one on the unit. Which I have prior to the current Firmware & Map update.
Following the FAQ's available re folder names & file name to the letter (poi.gpi) the head unit recognises a new file, but gives the error 'unable to open file' when it tries to copy from USB memory stick to DNX.
DNX is on current (updated) firmware & new 2012 garmin map (recently loaded). I am using Garmin POIloader v1.7 & PocketGPSworld database as I have previously.
Any advice much appreciated
Mike
keirhopley
PostPosted: Thu Nov 08, 2012 12:18 am    Post subject: Reply with quote
I have exactly the same problem, only on a Kenwood DNX4280BT. I loaded successfully the first two occasions but now I am getting the same error messages. Did you manage to resolve the problem?
Keir
CA_0610130749
PostPosted: Thu Nov 08, 2012 10:12 am    Post subject: Reply with quote
Sadly gave up on it as sold the unit with the car as I found it slow and annoying.
Whilst deleting stuff off it b4 sale I did find a setting in the garmin mapping sw that deleted all POI's which I hadn't noticed. Something like restore all/factory defaults which kept new map/firmware but removed the custom POI's.
I didn't ever try putting them back on, but that may sort it if it deletes the old ones first.
22.051 (01 May 24)
