Newsletter
Pocket GPS World :: View topic - TTgo 720, how to hear the spoken instructions, blue tooth
ned1
PostPosted: Wed Apr 25, 2012 6:58 pm    Post subject: TTgo 720, how to hear the spoken instructions, blue tooth Reply with quote
Hi all,
I have a tom tom 720 and have been using it on my motorcycle with ipod ear phones, what I would like to know is can the 720 go wireless with the spoken instructions and if so how, also
which blue tooth units work and which are best at a sensible cost
How do you select the 720 on to hear the spoken instructions.
Thanks for any help in this matter
Ned
ps, will a ttgo work if put in a back pack or do's it have to be upright and facing the right way Embarassed
PostPosted: Wed Apr 25, 2012 7:05 pm    Post subject: Reply with quote
A Go720 can work using Bluetooth for audio output as long as the Bluetooth device it is connecting to supports A2DP Protocol, this is stereo audio over Bluetooth, not many single earpiece devices will offer such connectivity as stereo needs both ears!
To select BT Audio output make sure Bluetooth is switched on, it's an option within change preferences then got to Change Preferences/ Speaker options and select Bluetooth for navigation and music playback.
The oriantation the TomTom is at has no bearing (sorry no pun intended) on either your speed, heading or direction of travel, it can work out which way it is travelling from the GPS signal - Mike
ned1
PostPosted: Wed Apr 25, 2012 7:51 pm    Post subject: Reply with quote
mikealder...thanks for that,
will have to try and find something suitable with A2DP Protocol
Ned
PostPosted: Wed Apr 25, 2012 8:48 pm    Post subject: Reply with quote
Are you after something for Bluetooth audio for the Bike, Car or when on foot as it's difficult to understand exactly what you are wanting from the original post? - Mike
ned1
PostPosted: Wed Apr 25, 2012 10:16 pm    Post subject: Reply with quote
To use with blue tooth on my motorcycle for spoken instructions only
ned Wink
ps I found this,that looks like it may fit the bill !!
http://www.ebay.co.uk/itm/170795962023?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
AliOnHols
PostPosted: Thu Apr 26, 2012 5:56 pm    Post subject: Reply with quote
ned1, I can confirm that my SonyEricsson HBH-DS200 bluetooth Headset & Speakers work Ok with my Go930.
Also obtained from eBay a couple of months ago for about 16quid.
EDIT - Currently about the same price as yours but a little cheaper at Amazon.
Garmin Nuvi 2599
SatMap Active 10 & 12.
ned1
PostPosted: Fri May 04, 2012 4:56 pm    Post subject: Reply with quote
Got my Sony Ericsson MW-600 Wireless Bluetooth Stereo Headphones today
and gave it a try my ttg 720 sees it but when I try to connect this comes up on the ttgo screen
MW 600 unable to use this device for hi fi audio playback the required features could not be found for this device.
this is part of the add,
◦Multipoint Bluetooth and A2DP for wireless music streaming
and here is the whole thing
thanks for any help that you may give.
Ned Crying or Very sad
PostPosted: Fri May 04, 2012 5:42 pm    Post subject: Reply with quote
Have you got the headphones paired to your phone per chance prior to trying to connect the TomTom? If so delete the pairing with the phone and try again with the TomTom - Mike
ned1
PostPosted: Fri May 04, 2012 7:00 pm    Post subject: Reply with quote
Hi mikealder,
No , the only thing that I have tried is the ttg,
I removed my phone from the ttg and tried again,
the ttg sees the mw 600 but when I select it it comes back with
same as before !!
Confused
ps My ttg 's sound is from one earpiece only !!
AliOnHols
PostPosted: Fri May 04, 2012 9:59 pm    Post subject: Reply with quote
Hi ned1, just confirming that you have selected the "Speaker" to channel through Bluetooth as mikealder mentioned earlier.
Garmin Nuvi 2599
PostPosted: Fri May 04, 2012 10:02 pm    Post subject: Reply with quote
Also double check the BT is actually enabled, I have seen some stupid error messages from devices when trying to connect when the BT is disabled - Mike
ned1
PostPosted: Fri May 04, 2012 10:30 pm    Post subject: Reply with quote
It finds the device and is listed as mw 600, then it comes back with when selected, :-
I was wondering if the fact that the ttg is seems to only work on one earpiece which was happening with wired headphones has anything to do with it.
Had no problems with my phone with BT on the ttg
AliOnHols
PostPosted: Sat May 05, 2012 6:46 am    Post subject: Reply with quote
ned1, The specs of your SE mw600 and my SonyEricsson HBH-DS200 appear to be equal, just the design of the models differ and my SE works with my TT Go930 (with v 8.351 software) so it should be a matter of not giving up. Try some re-sets, the Clear Flash tool.
There is this thread from AndyVaughan of a few years ago.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=67502&postdays=0&postorder=asc&start=0
Some good reading on the troubles of Bluetooth, the fix for AndyVaughan appears half way down on page 2.
Garmin Nuvi 2599
ned1
PostPosted: Sat May 05, 2012 9:31 am    Post subject: Reply with quote
Thanks for that AliOnHols,
Just had a look at which software I am running and it's 7.221
is it possible that a software update would sort it out.
Would I be able to load the same software into mine and if so where and how can this be done.
Going to have a read of your link later on.
Thanks again for your help
Ned
AliOnHols
PostPosted: Sat May 05, 2012 9:44 am    Post subject: Reply with quote
The NavCore I prefer for my 730 is v8.351 which is ok for your 720 also (TT have just released a v 9.xxx - but i don't really know anything about this other than I don't want it). Links to v8.351 can be found by using the search button above, I always use the keywords "whitepilgrim volume". Do not use TT Home for this as it shall foist the v9.xxx version upon you .
I know you know, but please, please make a full Windows Explorer (or similar) back up of your SatNav before doing anything else. Don't rely on a TomTomHome backup.
Garmin Nuvi 2599
20.094 (28 Sep 22)
Terms & Privacy
