Pocket GPS World :: View topic - Satmap Route Profiles
trav
PostPosted: Mon Oct 19, 2009 4:14 pm    Post subject: Satmap Route Profiles Reply with quote
Does anyone know if it is possible to see route altitude profiles when downloading a GPX route.
I download a GPX route file from walking world. Use the Satmap route planner to import this GPX file into the planner. The info is there, profile is shown in the planner for altitudes on graph. I edit the route slightly, rename it and save it.
I then use the Satsycn software to convert to a MAP file and send to the Satmap.
The route appears on the map on the satmap, but there is no profile data as it just shows a flat line profile. When looking at the waypoints on the route, the elevation altitudes are there, but not reflected on the satmap graph. This cant be right surely?
Any ideas?
Graham
jonesbach
PostPosted: Mon Oct 19, 2009 6:43 pm    Post subject: Reply with quote
When you design a route on the Satmap route planner and import into the Satmap you can display an altitude profile. I would guess the problem is related to the tag name used to store the altitude in the Walking World route. Perhaps the Planner is not importing the altitude but displaying the profile by looking up heights from its own tables. When the route is saved heights are may only copied when points have been entered via the planner and all other points saved as imported. Difficult to explain and perhaps wide of the mark, but a possibility.
stevendunn99
PostPosted: Tue Oct 20, 2009 9:11 am    Post subject: Reply with quote
I use bikehike.co.uk to create routes and the altitude profile works after import. As bikehike offers you multiple map choices you could use that for walking routes as well if you want an alternative.
tenko21
PostPosted: Tue Aug 30, 2011 2:00 pm    Post subject: Re: Satmap Route Profiles Reply with quote
Had the same problem importing from Memeory Map. gpx files.
Solution:
Go into Satsync options (spanner symbol)
Routes import tab
Downloads option
tick "Always fetch height data from the internet" option
Voila !!!
Dont forget to reboot machine to see changes
Tenko21
Any ideas?
Graham
rothers
PostPosted: Tue Aug 30, 2011 2:22 pm    Post subject: Reply with quote
SportTracks (free version) with the Elevation Correction plugin is also very useful for adding elevation data to .gpx files which lack it.
http://www.zonefivesoftware.com/sporttracks/
