Pocket GPS World :: View topic - On startup also run ("Navmii") is this possible
RobboUnited7
PostPosted: Thu Apr 07, 2011 8:46 pm    Post subject: On startup also run ("Navmii") is this possible Reply with quote
I have a question regarding "on startup also run" as I use Navmii GPS and i wanted to know whether you can use the satnav at the same time as the Camera App. What do i need to put in the Custom URL if it is possible.
Any response will be helpful thanks, RobboUnited7
PostPosted: Fri Apr 08, 2011 9:32 am    Post subject: Reply with quote
do they have any sort of 'share a location with a friend' option? that's usually the best giveaway - if it has an email option then it will usually allow your friend to open it directly in the app.
i've just tried it with NavFree (don't have NavMii installed) and it uses navfree:// I would take a guess that using navmii:// should work
