Pocket GPS World :: View topic - Route Planning question..
FrequentFlyer
PostPosted: Wed Mar 16, 2011 5:56 pm    Post subject: Route Planning question.. Reply with quote
I've been trying to play around with the route planning feature as I am committed to lead an 18 mile walk shortly. Question. I have zoomed into the 1:25 option to really see the paths that I want to take. I have completed and saved the walk.....how do I now print it off on to an A4 sheet that shows the 1:25 walk...(for the back marker.) It appears to me that it would be easier to use a highlighter on my OS map and purely copy it, as using the print feature seems to knock it back to 1:50 so that it fits into the Satmap screen/square that you have to use. Thanks.
Bosun
PostPosted: Wed Mar 16, 2011 8:45 pm    Post subject: Reply with quote
Just to clarify,are you trying to print direct from the A10 or are you trying to print the route from Satsync ?
I haven't tried either option but there is a "Print" icon in Satsync.
Ian
FrequentFlyer
PostPosted: Wed Mar 16, 2011 9:12 pm    Post subject: Satsync Reply with quote
I'm trying to print from Satsync...but if you press the print option, the map/route you've created in 1:25 seems to default back to 1:50 to fit the Satsync box on the PC monitor...in other words I can see the whole route in 1:50 but not 1:25..as when you create it, you're moving around up / down etc., outside of the box area...(if that makes sense!)
All I'm looking to do is print the 1:25 map I've created onto an A4 sheet, but how ?
22.053 (15 May 24)
