Pocket GPS World :: View topic - 1690 can I delete specific Proximity Alerts?
tailz
PostPosted: Mon Jan 17, 2011 5:32 pm    Post subject: 1690 can I delete specific Proximity Alerts? Reply with quote
I have just purchased a Nuvi 1690 and used it today for the first time in a trip up the M1 past Nottingham. I have the proximity alerts switched on and as I reached the point on the M1 where the road works used to be passing Nottingham I got a warning about the 50mph variable speed limit cameras. Obviously these cameras have been gone for a while now, so I would like to remove them from the database, can someone explain if this is possible and how please? I have a quick butchers through the previous topics and could not see anything, so if I missed a previous post i appologise.
Tony
PostPosted: Mon Jan 17, 2011 5:42 pm    Post subject: Reply with quote
If these are Garmin speed cameras then no, you can't manually edit them.
But, if you were to subscribe to our speed camera service, the data would be up to date - we have much better, more accurate, and more up to date speed camera data than the service Garmin use.
tailz
PostPosted: Tue Jan 18, 2011 4:35 pm    Post subject: Reply with quote
Thanks for the reply Darren, I will give some thought to subscribing to the camera database
PostPosted: Tue Jan 18, 2011 5:08 pm    Post subject: Reply with quote
Feel free to peruse our submission map here. That should prove that our data is current, check the M1 roadworks cameras that are incorrect on your Garmin.
SQUARE2024
PostPosted: Wed Jan 19, 2011 10:27 am    Post subject: Reply with quote
There is no contest when it comes to what Data base to use
Square2024
TomTom 520
Christmas Draw 2010 Grand Final Winner Garmin Nuvi 1490TV
tailz
PostPosted: Wed Jan 19, 2011 5:18 pm    Post subject: Reply with quote
You smooth talkers..ok..off now to sign up.
tailz
PostPosted: Wed Jan 19, 2011 5:52 pm    Post subject: Reply with quote
All done and signed up, just 1 question though,
I have downloaded both the UK and Euro databases, installed the UK one first, then changed the name from poi.gpi to UKpoi.gpi, then I loaded the Eur database and renamed that to Eurpoi.gpi. When I go the the proximity alerts settings on my nuvi, I just have the 1 Custom POI's option listed and ticked, is that correct or should I have 1 for UK and 1 for Eur?
Tony
PostPosted: Wed Jan 19, 2011 5:56 pm    Post subject: Reply with quote
You should see two sets of categories. Browse to your device and confirm both .gpi files are still present.
tailz
PostPosted: Wed Jan 19, 2011 6:30 pm    Post subject: Reply with quote
I have renamed both gpi files so now I have eucams and ukcams still only 1 custom poi listing in settings but I am getting cameras showing up both in the UK and France so all appears well.
PaulB2005
PostPosted: Wed Jan 19, 2011 8:15 pm    Post subject: Reply with quote
Iirc you will only see one Custom poi category regardless of how many GPI files you have loaded.
PostPosted: Wed Jan 19, 2011 8:23 pm    Post subject: Reply with quote
Really? The sticky suggests otherwise but I don't have a Garmin to test - You've got it Wink
PaulB2005
PostPosted: Wed Jan 19, 2011 8:38 pm    Post subject: Reply with quote
Ah right. I did try it once seperating my non Speed Camera POIs from the Speed Camera POIs so i'm working from memory which is never a good idea in my case..... I think... Shocked
At the minute you are significantly closer to it than i as my mum is using it.... Did you need it back? Wink
PostPosted: Wed Jan 19, 2011 9:07 pm    Post subject: Reply with quote
No, just pulling yer leg.
22.053 (15 May 24)
